  • Moar Powar Babeh
  • Member For: 19y 9m 4d
Will tig up a custom fitting before condemning a brand new fuel rail.
  • Bronze Donating Members
  • Member For: 13y 11m 6d
  On 20/05/2014 at 11:40 AM, Ralph Wiggum said:
The fitting in the rail is ORS, not much chance on landing on exactly the right orientation unfortunatly
Thread tape lol
  • Moar Powar Babeh
Will go see my fittings dude tomorrow to measure these:
post-7403-0-49653000-1400591836_thumb.jp
Against the full flow elbow I have now
Also on reflection I think I can mill down the boss on the rails mil or two. As its an ORS fitting it shouldn't affect sealing.
  • Dropping a turd
  • Member For: 17y 8m
  • Moar Powar Babeh
Thanks Aaron,
That's actually what I was referring to in the previous post but I linked the wrong Pic.... :ermm:
ORBS to AN Adaptor 90deg-
post-7403-0-12335900-1400628591_thumb.jp
Couplers in Malaga are getting two in for me this arvo. Should give me sufficient clearance as they are aprox 22mm shorter than the usual ORBS adaptor/90deg hose end combo.
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 27d
Hey ralph what fitting do u have at the rear of the plenum for the brake booster line ?
  • Moar Powar Babeh
Just the Stock Nizzer Christmas tree fitting. I have tapped and additional 1/8NPT port at the back of the plenum for my PCV return as it gets a bit busy in the normal spot when running a PCV Catch Can/Non Return Valve.
  • Moar Powar Babeh
For those playing along at home the Speedflow 922-06 ORBS-AN 90 is 36mm from the base of the ORBS threase to the outer edge of the AN thread (IE extreme height) VS Aprox 60mm for a ORBS to AN Adaptor and Full Flow 90deg.
The 922-06 has an ORBS thread length of 18.5mm so installed height will be aprox 17.5mm VS 40odd mm for the ORBS to AN Adaptor and Full Flow 90deg.
