  • Member For: 11y 2m 24d
hi just tried to fit a turbo 6 with a btr box into my ba ute but it just will not fit .do I have to lower the crossmember or can I just take the power steering of and the sway bar .what is the easiest ? got told by wreckers that they fit no problem .any info would be great .thanks
  • Im the one and only
  • Member For: 20y 3m 14d
Wreckers love to yank sh*t out with no care. Look, its probably doable but awkward. Did it with old motors years ago but I guess you dont want to split the box?
na just bolted it back together mate ,and the back bolts are a pain in the ass to get to on the fire wall .the v8 came out so easy with the box
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 21d
The angle u need is stupid but totally doable
Yeah the I6 is a long motor. A hoist would be the go. then you could bring the box up from underneath. I do remember the days of lifting top loader 4 speeds in from the bottom of the car on car stands. Dead lift over your chest on the ground while trying to not knock off the clutch arm as you go through the thrust bearing. :mda:
I changed the chain 2 times to get different angle ,but both times I was unable to get the engine in .the last time the power steer rack was in the road ,so I might just undo the cross member to get more room .its a long motor which hits on the fire wall and the front radiator support and then fouls up at the power steering rack . I am gunna try again tomorrow .
  • Moar Powar Babeh
  • Member For: 19y 6m 29d
I have tried and aborted. I used a engine crane and load leveller and couldn't get enough angle to clear the front X Member before the trans fouled the floor.
Jacking the car up higher to get the trans to clear the floor ment I ran out of height on the crane.
In short I gave up and fitted the trans first.
going to try to lower the crossmember now ,I will keep you posted how I go .never give up , I got a hacksaw and sledge if it does not work after that .
  On 19/05/2014 at 12:29 AM, ratter said:
Long motor, that's your problem then, get a standard size one ;)
was trying to shrink the engine but the dryer door would not shut ,so I gave up :stupid:
