Error Codes, Overboosting, Exhaust Howl, Pulled Turbo Off And Cant Fin
  • Member For: 11y 10m 4d
I blew regulated air into the wastegate actuator and it failed to open, at any point. The air was leaking out of the small hole in the side and at the bottom where the rod comes out. So my assumption is that the diaphragm has a hole in it and is leaking
Wizzing sound was coming from missing bolt on waste gate bracket that went right through to the intake side of the turbo. Got it all back together and car is going a lot better, still making the 'howling' noise from the exhaust though. And on a test drive it briefly saw 18psi before I jumped off the gas :/ so I have to be very carefull until I get a new actuator.
