Fg With F6 Turbo With .7 Front Housing
nathanway
  • Member For: 13y 4m 28d
hello all
first id like to thank everyone on helping me and everyone else out so much, I cant stress how much this web site has helped me over the years
so ive got a fg xr6t 100xxxklms
mods are turbo back exhaust
injectors
rapidsystems v2 intake and intercooler kit
valve springs
xcal 3 and dyno tune to 303rwkw
ive got a turbo of a low klm f6 (not installed)
ive got the gate ported and new flapper with 12psi actuator
ill have to get a new in tank pump and not go below half a tank ( cause im a cheap ass and cant afford a surge tank and .44 setup)
and a retune to about 16-19psi on 98 im hoping for between 375-400 and once the box is built im hoping for a 10.9 1/4mile with semi's
I was under the impression that a stock f6 turbo could make these numbers but I few mates are saying that ill only get to about 360ish with this turbo , so now im considering getting a .7 front cover for the f6 turbo as well
has any one else done this mod and what do you guys think of my set up
is the new cover necessary and is the time im looking for doable if its not ill be changing the injectors straight up to to 1000cc ones and doing a e85 tune
if this fails to get to the 10.9 ill be doing a e85 tune ( out of a barrel $2.50perL) than I know ill get it
thanks for all the help guys
  • Member For: 13y 8m 23d
Iv got the 0.7 cover with a 66mm wheel built by Monsta torque and I'm making 480rwkw on E85 it still has some left in it. With this set up I ran a 10.755 but that was with a little bit of wheel spin. Was hoping to head down tonight again but it'll be rained off. On 98 I made 410rwkw on 17psi and I couldn't get it into the 10sec (only tried one night)
  • MattyP
  • Cruise Control
  • Member For: 12y 7m 30d
Hey mate
I wouldnt bother with a .7 cover unless you plan on going a bigger wheel
I went an 11 blade billet wheel compressor wheel from kinugawa on a 3540 with the wastegate port and flapper done
I made 363rwkw on 98 on a brutal dyno and I will be taking it to the drags soon on 98 to see how it runs
As for the surge tank (this will be a really unpopular opinion on here) but I dont recommend them unless you are running huge power, for me they are way to noisy (especially the 044s) and add alot of complication to the fuelling system
A walbro 460 with a Reg would suffice at your power level
I run the kpm 1000hp intank fuel pump and its perfect for my car (413rwkw on E85 and handles it without an issue)
Surge tank is cheap insurance, most people use them because they are tried and tested and proven that you need one. I will admit the 044 pump is very noisy but there are many other options of pumps out there that are been used
  • MattyP
  • Cruise Control
I would hardly call a surge cheap
I'd never tell anyone not to get one but I really don't see the point at 400rwkw it isn't really necessary and most people still use the original pump feeding the surge
It's just 2 pumps that could fail now and if either one does die it'll still cause massive issues
I like it quiet and simple and nothing underneath my car
If you go a surge I'd go twin walbro 460s
Much quieter than the 044
Each to their own I suppose
Plenty run them
Plenty don't
Just do your research into what you want from your car and go from there
  • Member For: 18y 4m 13d
He means its cheap insurance, as in buying a surge is cheaper then your engine running lean, blowing up and then having to rebuild it.
  • MattyP
  • Cruise Control
I really just don't understand the fanaticism with surges in our taxis
I know what he's trying to say but people who use the oem fuel pump and one single 044 or 460 run just as much of a risk if not more so of running lean and blowing up.
If the oem pump goes it's still gonna run out of fuel, it'll just take a little longer
Surges are great for high horsepower track warriors but as a Streeter, what's the point?
Yes yes "insurance" but is it really that much safer?
I don't think so
But that's my opinion
OP should do what he's comfortable with, I'm just saying there is alternatives out there
  • Member For: 11y 27d
I wouldnt run 400+ kw without a surge tank. The stock setup is poorly designed and is easy to see how it would struggle to supply adequate fuel for much higher than stock hp... given people have fuel supply issues simply on low tanks I think its a must do mod. Having said that, aesthetics aside paying $1000 for a small tank, fittings, and a $150 pump is excessive. Race car engineers have been building surge tanks for years, theres no unique needs for an xr6t.
Edited by luke187
