Questions On Changing Actuator To 12Psi Without Re-Tune?
alan_fgxr6TMK2
  • Member For: 10y 7m 11d
hey just asking for some information on changing out the actuator from standard to aftermarket turbosmart 12 PSI.
I have a fgxr6T mk2 current mods
CAPA STEPPED INTERCOOLER
CAPA ALLOY HOT/COLD PIPING KIT
PLAZMAMAN TBR REPLACEMENT
PLAZMAMAN 4'' INTAKE KIT WITH BATTERY RELOCATION
TURBOSMART KOMPACT B.O.V
I am running standard ecu tune if I change out the actuator to 12PSI is it necessary to have the ecu retuned to 12PSI also will the boost pressure be affected.
If I dont retune will the wastegate only open at 12PSI now?
thought I would ask instead of doing any damage
thanks
thanks
thanks
thanks
  • Member For: 18y 6m 19d
the wastegate may open at 24 psi,
except hopefully the ecu will go into boost cut and this will happen every time it try's to make boost if you have the factory tune
