  • Member For: 11y 2m 19d
just wondered if the gasket is necessary at all .only asking due to when I disassembled turbo from manifold there was no gasket .I have purchased a permaseal mls-r turbo gasket kit. is that ok to use or are there better ones ? or just do not fit one at all ?thanks for your help guys
  • Member For: 13y 8m 6d
Best to fit one, if for some reason the surface isn't true it will leak, at least fitting a gasket removes this possibly. I used a $30 ebay kit so your should suffice.
lol mine was e bay $40 . yes I will fit it .only running 15 psi ,so it will be fine
  • Bronze Donating Members
  • Member For: 13y 1m 11d
I had one fitted 6 months ago and it recently developed a hole in it
It was a cheap one from eBay that was a composite material
I am getting it replaced on Thursday and the turbo specialist doing the work explained that running a gasket is best but to fit a crushable metal gasket so it stays together
  • 3 weeks later...
  • Member For: 13y 1m 21d
I just removed a permaseal mls one last weekend as it had shrunk to half its thinckness over 12 months and made my car run rich as sh*t. was also using atomics bolt kit and even they went loose from the peice of crap shrinking. back to no gasket for me for now.
fitted mine and the engine is back in the car now . and its such a pain in the ass to take of the turbo .
  • 1 month later...
  • Member For: 22y 17d
I find gaskets cause issues, especially with them compressing on the corners and warping stuff and blowing out the gasket where it is not compressed.
Best thing is to have a good machinist machine the turbine housing and the manifold baby bottom smooth if the surfaces have degraded and not true.
I have added hi temp silicone between the surfaces and it does not really do much, but I have heard there is a product/sealant you can use that does not burn off between the matting surfaces but don't know what it is called.
Edited by turbotrana
