  • Member For: 14y 8m 8d
Pic will do the talking, Oil sprayed all over the motor in between turbo and power steering pump. Pump is a little noisey but nothing major
I initially thought head gasket but a mate told me it probably isnt and possible power steering pump is on its way out?
if it is what's the best option for a replacement? There's one on ebay that's a reconditioned genuine one for $150 posted, or should I try a low km one off a wreck?
https://www.fordxr6turbo.com/forum/topic/88150-stuffed-power-steering-pump/
  • Expert
  • Member For: 20y 4m
Does your power steering make a funny noise? If so that's what it is. No biggie about $200 I think and easy to change over. I had to replace one in my old BA
Doesn't look like any of the hoses are in issue but will take a better look
Yea if I run the car it sounds normal then start turning the wheel it makes a noise. The pulley has been a bit noisey in recent times aswell
Nah not enough doughnuts. Car has seen a few powerskids but never seen a doughnut (in my possession anyway)
Cheers Kosij I'll double check its the pump and give them a call monday morning!
Had a ford mechanic look at it today and he thinks the pump seems to be alright, he thought it's more likely to be the timing case leaking :/
Never heard of that being an issue, is that a common ford problem? It's only the smallest amount of oil because the oil level has never dropped on me
Yea I don't have a decent pressure washer available here in canberra, will have to wait till I go home next. Power steering feels fine and not using any oil so hopefully nothing too bad
