JWM Member 14 Member For: 16y 5m 23d Posted 03/05/14 12:04 PM Share Posted 03/05/14 12:04 PM Try turning the springs around a bit. I had this problem as well, but you can see the lower control arm sits on an angle while the top of the spring sits flat. This means the end of the coil needs to be either towards the diff or towards the wheel. You can raise / lower the car by a small amount by turning the springs.The springs were probably just shoved in and left in what ever position they popped in at, I did it at first and my mates car which was already lowered was the same, and had the same problem. I think I turned my springs so that the end of the coil was towards the diff, pretty sure that lowered it as much as possible. One spring end will face the front of the car and one will face the back.Hope that helps, it's kinda hard to explain... Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 9m 11d Gender: Male Location: adelaide hills- 'race air' central Posted 04/05/14 01:14 AM Share Posted 04/05/14 01:14 AM if no joy then slip a 10mm nolathane spacer between the top rubber and the body- NOT between the spring and the top rubber.@SteveR wtf? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m Gender: Male Location: Perth Posted 04/05/14 01:46 AM Share Posted 04/05/14 01:46 AM Or stay in the car and grow long arms. Steve must be drunk again Link to comment Share on other sites More sharing options...
dl86 New Member 5 Member For: 11y 3m 6d Posted 25/10/14 01:33 PM Share Posted 25/10/14 01:33 PM I've been having this issue as well.To get the rear level this is what my rear springs need to be set at Any logical explanations for this? 1 Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 8m 2d Gender: Male Location: Sydney Posted 27/10/14 08:11 AM Share Posted 27/10/14 08:11 AM I've been having this issue as well.To get the rear level this is what my rear springs need to be set at Any logical explanations for this? That's a bit of a difference!I know when I took some rear springs out of my car one side (I think it was the left) had compressed quite a bit more than the other.The cars tend to squat on the left and lick the rear out to the left don't they?May compress the spring on one side more than the other.Rotating LHS to RHS springs could be the problem unless the diff is not aligned. 1 Link to comment Share on other sites More sharing options...
