Robert21 Member 15 Member For: 10y 6m 5d Posted 01/05/14 12:01 PM Share Posted 01/05/14 12:01 PM Hey Guys!I have just bought myself an 09 XR6T Manual and I am quite new to Fords so I was hoping to get a little bit of advice!After driving the car for a week or so I have noticed that when the clutch engages there's an awful clunking noise that accompanies it. (which I didint hear when I took it for a test drive) This is happening even when I am not moving, if the car is running and I pump the clutch in an out whilst in neutral it clunks on the way out just after where friction point would be but this does not happen when the car is off.I have searched the forum and haven't found a post resembling my issue and I just wanted to know if anyone else has experienced this before?Any help would be appreciated!Thanks guys Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 9m 1d Gender: Male Location: Sydney Posted 01/05/14 12:10 PM Share Posted 01/05/14 12:10 PM loose flywheel?that problem is fairly common, not sure how common on FG's 1 Link to comment Share on other sites More sharing options...
Robert21 Member 15 Member For: 10y 6m 5d Posted 01/05/14 12:28 PM Author Share Posted 01/05/14 12:28 PM loose flywheel?that problem is fairly common, not sure how common on FG'sHaven't heard anything about the flywheel being defective on any of the forums, its coming from the front as well so I guess I've ruled out the bushes..I have been looking for a while now and apparently they all make clunking noises.. but I didn't think it was that loud or surprising Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5d Gender: Male Location: Perth Posted 01/05/14 12:41 PM Share Posted 01/05/14 12:41 PM (edited) Take it back for warranty. Could be many thingsDodgy CSC Edited 01/05/14 12:42 PM by arronm Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 9m 1d Gender: Male Location: Sydney Posted 01/05/14 12:41 PM Share Posted 01/05/14 12:41 PM Never heard about loose flywheel bolts on any of the forums?Havent looked real hard....lolhttp://www.fordxr6turbo.com/forum/topic/84568-loose-flywheel-bolts/ Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 10d Gender: Male Posted 01/05/14 08:33 PM Share Posted 01/05/14 08:33 PM Normal mine has done it from new, FG mk2.. 60000ks. Stop stressing . Link to comment Share on other sites More sharing options...
sixman Donating Members 600 Member For: 20y 3m 10d Gender: Male Location: Hills District, NSW Posted 01/05/14 09:24 PM Share Posted 01/05/14 09:24 PM My fg2 does it as well. Also makes the noise wnen suddenly coming off the loud pedal- actually feels like the chassis is rocking back and forth on the driveline.Sound deadening for audio purposes has reduced a lot if the clunks... Link to comment Share on other sites More sharing options...
Robert21 Member 15 Member For: 10y 6m 5d Posted 01/05/14 11:32 PM Author Share Posted 01/05/14 11:32 PM My fg2 does it as well. Also makes the noise wnen suddenly coming off the loud pedal- actually feels like the chassis is rocking back and forth on the driveline.Sound deadening for audio purposes has reduced a lot if the clunks...Yes that's exactly what is sounds like!I thought I had stuffed something already! Well I'll try the sound deadening and see if that makes me feel any better otherwise I'm going to take it bak to Ford and see if they can do anythingDo you know why it makes that sound? Is it a clutch or gearbox noise specifically? Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 10d Gender: Male Posted 01/05/14 11:57 PM Share Posted 01/05/14 11:57 PM Ford will tell you it's normal and within tolerance. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5d Gender: Male Location: Perth Posted 02/05/14 12:40 AM Share Posted 02/05/14 12:40 AM Ford will tell you its the clutch pedal hitting the floor mat. 1 Link to comment Share on other sites More sharing options...
