  • Member For: 11y 3m 16d
  • Gender: Female
  On 06/05/2014 at 12:38 PM, McMattyP91 said:
All good I've got 20s on my g6 and I reckon they are too big
How low is yours?
Sent from my SM-N9005 using Tapatalk
  • Gender: Female
  On 06/05/2014 at 12:40 PM, McMattyP91 said:
Standard height atm
About to lower it by a little
But it's sooooooooo noisy[/quote
Ahhh ok then :) mines a ute so stock height just looks silly with rims and stuff (to me anyway) the sedans look much lower stock. Mine has a 3.5 inch from cat back and it's ridiculously loud haha :D
  • Gender: Female
  On 06/05/2014 at 12:46 PM, McMattyP91 said:
Why not a full system?
Way more power and response
When I bought it I didn't want it quite so I told the dealer to put an exhaust on it from cat back until I got it tuned :) I've only had it 3 months but I'll get it done soon when I upgrade my injectors and intake. It shoots flames.....
  • MattyP
  • Cruise Control
  • Member For: 13y 25d
and get a cooler and piping while your at it, and TBH I wouldnt stress about the intake, just get a good panel filter and cut a hole in the stock box
  • billet turbos and weathered engines dont mix
  • Member For: 13y 8d
Do your suspension first, then work out what wheels you want and what will fit. I had my fg ute reset 4 inches in the rear (think the leaf basically upside down just sitting there) and ultra low springs in the front. there was no way I would have fit 20's, let alone 22's without them only being a horrible offset. I rekon some 19's or 20's if you want big rims with a good offset will look spot on. if you want 20's, you coouuulllddd possibly do 22's in the rear with an 8.5 or 9 inch rim with the offset high enough to sit them inside the gaurds, but youll be tucking a good 2 inches of rim in the rear!
At the end of the day its your car and you build it how you want, just remember alot of the guys on here are all about performance which is why they will push to have smaller rims, wider tyres etc haha. I think big rims can look good, but also remember youll have skinny rubber, potholes are going to be your worst enemy, and my ute with the stock 18's were already getting a little rough being that low. If you're prepared to put up with those things go for it!
  On 30/04/2014 at 12:15 PM, FILTHYFG said:
I have a query for any wheel people out there, ive just lowered my 6T quite alot as you can see in the photo, I just wanted to know if 22x9.5s will fit on it with out too much trouble?
Sent from my iPhone using Tapatalk
I mentioned previously, runnign this low with huge rims, youre gunna have the roughest ride going. But its youre car and you build it how you want. 22's will fit, 35-40 offset, but youll be tucking serious rim and running on the smallest profile tyres so watch even pebbles on the road ;)
