  • Member For: 12y 3m 9d
Hi everyone I'm having some issues with my 6 speed manual. It is an 09 xr6t ute.
When changing from 1st to 2nd it is hesitant and ever so slightly grinds. The best way ive found around this is to slowly pull the gear knob from first gear into neutral for a short time and then into second (if that makes sense).
The ute had 8000kms when I bought it and changed all fluids straight away. I used castrol transmax z. Now has 27000kms but has done it ever since I purchased the vehicle.
Any advice is appreciated cheers.
https://www.fordxr6turbo.com/forum/topic/88131-6spd-2nd-gear/
  On 30/04/2014 at 11:06 AM, Pazzo said:
Mine does it. Worse when cold. But once warm
It's ok. Plenty if FGs do it. Notchy shiftys aswell don't help.
Yes its worse when cold but still there when warmed up. I'm going to try mainlube gear oil at 30000km and see how that goes.
  On 30/04/2014 at 11:27 AM, visine said:
One of the pleasures and pain of owning a manual. Never had 6060 box but had t56 and the noises,clunks,bangs & roll over that came out of that box. So in short it's normal.
Ive owned a few t56 but none have been like this, I don't think its normal, all the other gears are fine just second.
  • Member For: 14y 6m 29d
It's normal, also comes down to how you drive, if you give it heaps the oil will go off quicker.
I'm going to do a oil change next week will let you know if it helps or not.
  • 3 weeks later...
