  • Member For: 19y 2m 22d
I would say that turbo would have gone to 20psi happily so probably more in it. Not a bad result. Would be awfully brutal down low on E85
  • Member For: 11y 11m 15d
Cost for the FG Turbo upgrade to the MTA center and new billet wheel balanced (MTA 650 Model): $1100.00 and 12PSI Actuator $130.00
I think from memory to upgrade to a bigger turbo is around $2000.00. But depends what you want to do with your car to which way you should go.
If the FG was just a spare car for adrenaline fun and just generally did track time you would go balls in and go bigger turbo and strengthen a lot of other running items on the car. With supporting mods build might be around $20,000.00
If the FG is a daily driver and also want a track weapon free flow (upgrade) the little turbo. With supporting mods the whole build prob around $12,000.00
Prices are including brake upgrade which will cost from $3,500.00 to $5,500.00 unless you get a lucky EBay break that can bring that cost down to around $2.500.00 all fitted prices approx.
  • Like 5
  • Member For: 13y 5m 20d
Ive been following your post with interest mate my FG xr6 turbo is a daily and just starting to sort out a few mods for it over
the next few months, any chance you know what a MTA 750 costs, and whether its suited as a daily or more for the weekend
track toy, I definately dont want to loose the low down response but still plenty of go
I want to see these graphs. My MTA750 has pretty much the same curve at same rpm as little turbo up to 3000rpm - little turbo flattened out a bit from here before nosing over at higher rpm whereas MTA just keeps making power. That's with a 0.7 cover too.
The MTA 750 is also a great option and is very close to the response of the small FG turbo so would be ok for a daily I reckon .
The low down response between the two would have to be very close I did try to post the graphs again but no luck this has happend to me in the past but eventually I get it to work.
Another option if you want just PM me your email and I can get the graph to you that way.
Cost on the MTA 750 give MTA a call I would be guessing but have to be around the $2,300.00 mark ?
  • Like 2
