genuine honest person Member 2,769 Member For: 11y 3m 29d Gender: Male Location: near brisbane Posted 28/04/14 11:56 AM Share Posted 28/04/14 11:56 AM just undo the diff it self one one side (u bolts )and then have a look at the bolt that goes thru the spring .the bolt is not that thick ,only about a m8 or smaller from memory .the locater is on the top looks like a dome shape and the bolt ,bolts up from the bottom I think . (will have to hold with a set of vice grips ) .the bolt may be broken of inside of it . its about one and a half years ago when I did that .(had to take spring apart to fit the tonne rated spacers between the springs ) before I could fit the xr springs, or my 16 inch wheels would not have fitted .xr must just be a little different .bugger about the rules for one tonne rated tyres or I would have 18 inch wheels Link to comment https://www.fordxr6turbo.com/forum/topic/88104-ute-rear-end-swaying/page/2/#findComment-1468075 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 3m 29d Gender: Male Location: near brisbane Posted 28/04/14 12:00 PM Share Posted 28/04/14 12:00 PM ps they are load plus from ironman (repco sell them as well ) they are easy to fit .there are video clips on u tube about them if you want to have a look . Link to comment https://www.fordxr6turbo.com/forum/topic/88104-ute-rear-end-swaying/page/2/#findComment-1468078 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 4d Gender: Male Location: Perth Posted 28/04/14 01:33 PM Share Posted 28/04/14 01:33 PM On 28/04/2014 at 11:36 AM, XAH03 said: It does feel like the diff is floating in the car, it might be that the bolts are located.It will be the spring pads. When you have the car jacked up try pushing the diff to one side (foot in the middle of the wheel) I'll bet it'll move. Link to comment https://www.fordxr6turbo.com/forum/topic/88104-ute-rear-end-swaying/page/2/#findComment-1468100 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 3d Gender: Male Location: Probably above atmospheric pressure Posted 29/04/14 05:53 AM Share Posted 29/04/14 05:53 AM Just don't shove it so hard it comes off the stands Link to comment https://www.fordxr6turbo.com/forum/topic/88104-ute-rear-end-swaying/page/2/#findComment-1468231 Share on other sites More sharing options...
