genuine honest person Member 2,769 Member For: 11y 2m 26d Gender: Male Location: near brisbane Posted 26/04/14 11:06 PM Share Posted 26/04/14 11:06 PM hi ,I bought a 12 psi turbosmart actuator and a turbosmart electronic boost controller (e street only ) so is it possible just to run 6 psi on one of the settings for street use ? can the boost controller do that ? just do not know if that could work . the only reason I ask ,if my misses drives the ute she just would sh*t her pants when boost is that high .my ute has about 330 plus rwkw .thanks for your replies . Link to comment https://www.fordxr6turbo.com/forum/topic/88100-have-a-12-psi-actuator-electronic-boost-controller/ Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 27d Gender: Male Location: @ my laptop Posted 27/04/14 01:09 AM Share Posted 27/04/14 01:09 AM you are going to need a tune anyway so why not just have 2 tunes an a xcal?you will not be able to run less boost than the controler Link to comment https://www.fordxr6turbo.com/forum/topic/88100-have-a-12-psi-actuator-electronic-boost-controller/#findComment-1467777 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 2m 26d Gender: Male Location: near brisbane Posted 27/04/14 03:05 AM Author Share Posted 27/04/14 03:05 AM I have a sct flash tuned by elite .so using the 12 psi actuator I can not go bellow that setting ?and yes I will get a retune done ,have done a lot of mods to ute so tune will be wrong . can I change the spring inside actuator to suit both 7 psi to 15 psi ?just thought it would be better to go a bit higher with the spring, have larger flapper mod done and a performance wheel fitted to standard housing (ba turbo). so do I really need a electronic boost controller ,thought they would be better to change boost on the go .hate to wait 15 min for sct to load up for the drag tune.also thought that the boost controller can keep boost more even ,no spikes or drops in boost .just started fitting up the boost controller but still trying to find the rpm wire from the car . Link to comment https://www.fordxr6turbo.com/forum/topic/88100-have-a-12-psi-actuator-electronic-boost-controller/#findComment-1467793 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 27d Gender: Male Location: @ my laptop Posted 27/04/14 10:40 AM Share Posted 27/04/14 10:40 AM you will have no better control with that controller except you don't have to wait 4 minutes to reflash the BA. Spring pressure is the lowest boost you can run with any type of controller. If you are planning on running different boost levels, you need to make sure the tune is set at those levels, do not think because it does not ping at 15 psi that it will not ping with 12 psi unless it has been tuned at first 12 and then 15, there is no rpm wire, you also have to buy a tach adaptor. Link to comment https://www.fordxr6turbo.com/forum/topic/88100-have-a-12-psi-actuator-electronic-boost-controller/#findComment-1467851 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 9m 22d Gender: Male Posted 27/04/14 11:09 AM Share Posted 27/04/14 11:09 AM Has anyone ever seen a tune selector switch like seen on the earlier falcons for these later ones? Link to comment https://www.fordxr6turbo.com/forum/topic/88100-have-a-12-psi-actuator-electronic-boost-controller/#findComment-1467853 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 27d Gender: Male Location: @ my laptop Posted 27/04/14 11:22 AM Share Posted 27/04/14 11:22 AM can not work on our cars Link to comment https://www.fordxr6turbo.com/forum/topic/88100-have-a-12-psi-actuator-electronic-boost-controller/#findComment-1467856 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 9m 22d Gender: Male Posted 27/04/14 11:54 AM Share Posted 27/04/14 11:54 AM That makes me a little unhappy. Link to comment https://www.fordxr6turbo.com/forum/topic/88100-have-a-12-psi-actuator-electronic-boost-controller/#findComment-1467864 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 2m 26d Gender: Male Location: near brisbane Posted 27/04/14 11:59 AM Author Share Posted 27/04/14 11:59 AM thanks for that info mate .bugger thought it could do that .I will let elite work it out I think ,may give them a call to se if I should fit the boost controller or not . 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88100-have-a-12-psi-actuator-electronic-boost-controller/#findComment-1467865 Share on other sites More sharing options...
