  • Member For: 14y 3m
hey all wondering if any one had removed the headlight lens ,,of the fgs the plastic lens,,,I know to get the light out need to remove the bumber,,,as the clear blinker lens that is inside of the light has dropped,,
cheers
https://www.fordxr6turbo.com/forum/topic/88090-fg-headlight-lens/
  • Member For: 12y 4m 13d
As in you need to take the actual assembly apart to access the inside? Not sure if these are the same but on some of my previous vehicles you need to heat them up (bake in an oven) to let the glue be able to pull apart but I'd check with someone else first...
