arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 1m 2d Gender: Male Location: Perth Posted 03/05/14 07:58 AM Share Posted 03/05/14 07:58 AM I had that once. Never letting her drive again. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 1m 2d Gender: Male Location: Perth Posted 03/05/14 08:00 AM Share Posted 03/05/14 08:00 AM Ford fix = floor mat. Link to comment Share on other sites More sharing options...
FGMKII Member 193 Member For: 10y 10m 18d Gender: Male Location: Western Sydney Posted 14/06/14 10:25 AM Share Posted 14/06/14 10:25 AM Ford told me the springs needed tightening got the car back after the service and instead of the squeak, I now get a hard line in my arse and a cracking noise. I have to say with this, the clutch rattling like a sh*tbox, hard to get in gear sometimes and the reverse camera being useless at night I don't think I'll buy another Ford. Pretty disappointing. Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 4m 22d Gender: Male Location: Perth, SOR Posted 14/06/14 10:44 AM Share Posted 14/06/14 10:44 AM The driver’s seat on my FG has also been squeaking for a long time. Last two scheduled services I brought it up and got the same reply and fix from Ford, we tightened some loose bolts. This Ford “fix” is good for a few weeks.Pulled the seat out this morning and this is what I found. Sorry its a bit picture heavy, but I thought it might be useful for others.These are some pictures of the seat base welds that are prone to cracking. Luckily in my case all the welds look to be ok.This is the top 4 corners of the seat base (seat base foam removed). All welds look good to me.top1.jpgtop2.jpgtop3.jpgtop4.jpgThis is the bottom 4 corners of the seat base. All welds look good here too.bottom1.jpgbottom2.jpgbottom3.jpgbottom4.jpgI noticed the seat base spring tensioners in the below pic creak when you apply pressure, where they rub against the seat base.spring1.jpgFix for creaking base tensioners is to put some hard U shaped rubber between the spring and the seat base metal.Before:spring2.jpgAfter:spring3.jpgNow to what I believe was the cause of the my seat creaking and what Ford service were fixing by tightening bolts.The seat base bolts to the seat frame via 4 bolts as can be seen below. These 4 bolts were not very tight and the seat base could have easily moved around with my weight in it.problem1.jpgFords solution here it to simply use a single nut for the jobs, which is obviously not working as it comes lose over time.fix1.jpgHere is a close up of one of the 4 problem locations where the base is tightened to the frame, all 4 were in the same state. The wear I believe is from torqueing the bolts down and also the movement when they go loose. Also note the silver bits of metal on the black frame, this can only be from the seat moving around and grinding the metal away.problem2.jpgproblem3.jpgThis is my fix to hopefully stop these from going loose. Flat washer followed by a spring washer and than the original nut.fix2.jpgWhile pulling the seat apart I also found that the two bolts on each side that attach the seat back to the seat base were not very tight at all. Below are the bolts I am talking about.seatback1.jpgA lap around the block and no creaking or squeking what so ever from the seat any more. Hopefully this fix lasts a bit longer than the Ford fix.Thanks Goran.My started to creak last week. I will pull it a part next week and do the same. Link to comment Share on other sites More sharing options...
