Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 16y 11m 4d Gender: Male Location: Sydney Posted 21/04/14 11:40 PM Share Posted 21/04/14 11:40 PM I wrote this out a couple of years back and most of it still rings true!But yeah most of it has been covered off by Boganspeed earlier.I don;t mind kicking off. ZF 6 speed drag racing my experiences/tips. 1st outing Things you'll need to do prior. Make sure you take any loose items out of the carMake sure you take a jumper for cooler months (beenie too if Sydney or Mel)Make sure you have a long sleeve shirt Make sure you have over half a tank or at least a 1/3 if you have a surge set upMake sure you take a Tyre pressure gauge ($10 from Supacheap) .Make sure you take helmet that complies to ANDRA AS/NZS1698 under 10 years oldMake sure you have an Andra license if you feel your car will dip into the 11's (WSID no longer has this rule and other tracks may have adopted this by now) best to check with the local strip. When your there. Best to arrive early to avoid being not let in and long cues through scrutineeringIf it's you 1st time tell the desk it is don't lie (they will usually give you an FTXXX number which also alerts the marshals that it's your 1st time and they will be a bit more patient with you/ help you.Park up in your respective lane and open your bonnet, good to get engine temp/bay temps down prior to the run.Take notice of which lane goes before you and (remember some unique or standout cars) this way if your watching or away from your car you'll know you better hurry back to your car. Time to go Tyre pressures I found 22 - 24 in street tyre worked best (but trial an error here guys) and MT's 17 - 18 NItto NT05r's 22Make sure you bonnet is fully locked down (some people just let it pop to cool and forget to push it back down)Move as instructed to the designated lane.If you don't want to do a burnout drive around the waterIf you intend to do a burnout make sure you traction control is OFFIf your doing a burnout just Drive for first timers is fine or Manual if you know what your doing.Street tyre burnouts only need to be a few seconds start in the water and slower come off the brake and dry the off in the dry surface for a second or two.MT's burnout maybe pull 3 gears in the water (power dependent 2 gears if under 300 kws) and slower roll out and screech upslowy approach the stage if your a first timer watch both the tree and the marshal as he will wave you up.Bring the 1st light on (pre stage) then bump forward (slowly roll) until the second (bottom light comes on - full stage)Now your ready to go.First timers you might just want to watch the lights come down to green and the simply off brake and mash pedal.Stalling up is the better method but does take practice and is dependent on a few things like tail haft spec, stall converter etc...I found 2200ish rpm to be a good starting point for stalling.I would bring up the stall gently and as I reached the designated rpm simply swap from brake to go pedal.If you a first timer best to start with DRIVEManual is a bit trickier but ultimately quicker.If manual I found pulling gears at 5500 to be about the best speak to your tuner to further refine this but the it best to pull it 500 rpm under the desired point due to human and mechanical lag.Now your humming make sure you keep it pinned he whole way (unless you feel or hear an issue then jump off right away) trying to be WOT slightly past the 400 meter mark.Now on the brake 2/3rs you don't want to be mashing on the brakes at over 200kms.Slow down to around 50 - 60 and then easy does it back along the return road.Make sure if its at night you turn your lights back OFFCollect your ticket and park back up in your lane pop bonnet.Repeat. Other stuff. It helps to go with someone that has a fair idea about these cars and they will be able to help you a lot in things you might forget about or habits you might have.Also they can help you interpret your time slip and tell you places where you might be able to improve or better still advise you on what limit you may only be able to reach on the night.Talk to other Turbo barra guys while your there and swap notes if amazing how much info you'll gain quickly if you do this.And most of all have fun.Warning DRAG RACING IS ADDICTIVE and EXPENSIVE. 10 Link to comment Share on other sites More sharing options...
natsxr6 Member 117 Member For: 16y 7m 28d Location: penrith Posted 22/04/14 09:29 AM Share Posted 22/04/14 09:29 AM Nice write up matty, spot on with everything Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 11y 10m 20d Gender: Male Location: Perth Posted 22/04/14 11:02 AM Share Posted 22/04/14 11:02 AM So who's guilty of leaving traction control on accidentally during the burnout. I did it once.. Quite embarrassing 3 Link to comment Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 5m 14d Gender: Male Location: South West QLD Posted 22/04/14 12:00 PM Share Posted 22/04/14 12:00 PM Haha I did the burnout fine at a test and tune once.. But they held us up because one of the guys in front dropped oil..So since it was fecking hot and of course aircon isn't an option we turned off the cars and stood next to them while waiting..Forgot to turn traction off on that launch.. Though was a bit annoyed we weren't allowed to do another burnout.. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 10m 21d Gender: Male Location: Frankston, 3199 Posted 22/04/14 12:05 PM Share Posted 22/04/14 12:05 PM /me puts his hand upTraction control on and car in drive for my first run - was wondering why no burnout, but too excited to think my way through a start up routine. Link to comment Share on other sites More sharing options...
Bfneo Member 17 Member For: 11y 6m 6d Gender: Male Posted 22/04/14 01:09 PM Author Share Posted 22/04/14 01:09 PM Great write up guys ! Really helpful and answering all my questions !Haha I'll make sure that I'll turn off the traction control haha last thing I want to do is embarrass myself !!! Link to comment Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 16y 11m 4d Gender: Male Location: Sydney Posted 22/04/14 01:30 PM Share Posted 22/04/14 01:30 PM Best thing about trying to do a burnout with TC on is that you wont do it again! 3 Link to comment Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 5m 29d Gender: Male Location: Brisbane Posted 22/04/14 08:23 PM Share Posted 22/04/14 08:23 PM Never been to the drags but my old BA used to override TC and switch itself off. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 5m 25d Posted 22/04/14 09:41 PM Share Posted 22/04/14 09:41 PM Manual or auto? Link to comment Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 5m 29d Gender: Male Location: Brisbane Posted 23/04/14 12:15 AM Share Posted 23/04/14 12:15 AM Me or the guy going to drags? Link to comment Share on other sites More sharing options...
