ratter Member 6,793 Member For: 18y 9m 6d Gender: Male Location: @ my laptop Posted 18/04/14 11:51 PM Share Posted 18/04/14 11:51 PM most people selling the GTX do not include a rear housing, your current one will fit on but requires the turbo port and flapper mod done to it.Most sellers give the impression that it is a straight bolt on arrangement, yes it bolts to the manifold and lines but there is more work to be done which adds to the cost Link to comment Share on other sites More sharing options...
joebags Member 5 Member For: 11y 3m 6d Posted 19/04/14 12:19 AM Author Share Posted 19/04/14 12:19 AM most people selling the GTX do not include a rear housing, your current one will fit on but requires the turbo port and flapper mod done to it. Most sellers give the impression that it is a straight bolt on arrangement, yes it bolts to the manifold and lines but there is more work to be done which adds to the cost thanks that helps alot! so basically I would be up for the $1700 and then like $600 to have my housing modded?ive seen a gt3540 with 15,000ks and already flapper and port mod, but im guessing that's with a ba housing which you sayd to stay away from McMattyp91 Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 6d Gender: Male Location: @ my laptop Posted 19/04/14 12:27 AM Share Posted 19/04/14 12:27 AM FG housings are better grade of metal and do not crack as easy.You also have to, get a reference fitting put on the front cover, a new actuator bracket or modify a supplied multi fit one, different size outlet hose and different size inlet pipe Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 10m 1d Gender: Male Location: Central Coast Posted 19/04/14 12:52 AM Share Posted 19/04/14 12:52 AM There is no cheap option here bud while the gtx may cost 1500 but to get the thing on properly it'll cost 2500 at least with the standard rear housingMy one cost me 550 for 3540 compressor core160 for actuator 150 for billet wheel 200 for a balance 400 for waste gate porting and flapper mod Link to comment Share on other sites More sharing options...
