joebags Member 5 Member For: 11y 4m 29d Posted 18/04/14 12:21 AM Share Posted 18/04/14 12:21 AM Hey guys pretty new on here so any help would be appreciated! ive tried to have a look around but cant seem to find an answer.I purchased a second hand G6et with 40,000ks on it 6 months ago and im starting to mod.I already have a stealth black stage 3 plazmaman cooler and a process west 4" race box (still need to buy the battery relocation and the other cooler pipes)my future plan was to buy: true trac diffoil line filter kit for turbosiemens vdo 80lb injectors3.5" X force exhaust system with 4" dumpwas going to get these all fitted by a family friend mechanic then get a tune at Gentech (im in canberra) but the bloke there sayd the FG turbo can only take 320kw max and I could get 300-315 without the exhaust or dump (because they can cause overboost?)so I was thinking do I just save money and do as he says and see how it is then save up and do a second upgrade and tune, OR just do the exhaust and either buy a BA turbo with port and flapper mod, or a gtx3582r from the start with one tune instead of upgrading turbo later? and if both those turbos would be a hassle free direct fit and I wouldnt have to change anything else? any advice on those mods ^ ^ and they way I should go would be appreciated! thanks Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/ Share on other sites More sharing options...
joebags Member 5 Member For: 11y 4m 29d Posted 18/04/14 01:08 AM Author Share Posted 18/04/14 01:08 AM and I forgot a walbro GSS340 fuel pump! Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/#findComment-1466100 Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 7m 20d Gender: Male Location: Penrith Posted 18/04/14 01:28 AM Share Posted 18/04/14 01:28 AM Stay away from the 80lb injectors go the ID 1000s much better injector, better spray pattern more aligned with our cars needs. Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/#findComment-1466102 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 1m 30d Gender: Male Location: Perth Posted 18/04/14 01:43 AM Share Posted 18/04/14 01:43 AM Seems most people bite the bullet in the end and upgrade the turbo from what I can see on here so might as well do it from the start if you can handle saving for longer Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/#findComment-1466108 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 4m 17d Gender: Male Location: CQ Posted 18/04/14 02:56 AM Share Posted 18/04/14 02:56 AM I did all at once to my fg 6xrt, bf turbo with .7 cover and bigger wheel, cooler, exhaust, injectors surge ect and got my tuner to email me a base tune so that I was able to drive it 500km to him. Do you have the money? Are you going to be content with 320rwkw for a while until you upgrade turbo? Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/#findComment-1466116 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 21d Gender: Male Location: Central Coast Posted 18/04/14 06:25 AM Share Posted 18/04/14 06:25 AM Try to steer clear of the ba/bf rear housing Mod your own housing and use a compressor/core from a ba/bf/fgf6 That's what I did to my g6et and I used a kinugawa billet wheel Rate the set up very highly Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/#findComment-1466163 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 29d Gender: Male Location: @ my laptop Posted 18/04/14 06:32 AM Share Posted 18/04/14 06:32 AM real happy how the wifes G6ET drives with the small turbo in it would only consider getting the gtx version of it rather than going the bigger turbo and taking away some it's low down power, but each to their own 3 Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/#findComment-1466166 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 21d Gender: Male Location: Central Coast Posted 18/04/14 07:22 AM Share Posted 18/04/14 07:22 AM Yeah ratter that's how I feel about the bigger turbo. it's great but nothing beats that response. I kinda want to out a billet wheel on the standard one and Chuck it back on Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/#findComment-1466178 Share on other sites More sharing options...
joebags Member 5 Member For: 11y 4m 29d Posted 18/04/14 11:45 PM Author Share Posted 18/04/14 11:45 PM On 18/04/2014 at 2:56 AM, Bonjaz said: I did all at once to my fg 6xrt, bf turbo with .7 cover and bigger wheel, cooler, exhaust, injectors surge ect and got my tuner to email me a base tune so that I was able to drive it 500km to him. Do you have the money? Are you going to be content with 320rwkw for a while until you upgrade turbo? I thought I was going to have almost enough money to buy all the parts but I was surprised with not one, but three rego reminders in the mail the other day so there goes 3 grand from the budget so I will probably just keep saving and buy parts along the way I guess! On 18/04/2014 at 6:25 AM, McMattyP91 said: Try to steer clear of the ba/bf rear housing Mod your own housing and use a compressor/core from a ba/bf/fgf6 That's what I did to my g6et and I used a kinugawa billet wheel Rate the set up very highly sorry mate I have a decent idea about mechanics in general but I am pretty basic on turbo details.. so your saying that best idea is to use a different turbo and use my current rear housing? I emailed a guy about a gtx3582r and he sayd my stock rear housing would fit straight on, so that's basically my best bet? Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/#findComment-1466321 Share on other sites More sharing options...
joebags Member 5 Member For: 11y 4m 29d Posted 18/04/14 11:47 PM Author Share Posted 18/04/14 11:47 PM and the GTX already come with the port and flapper mod correct? Link to comment https://www.fordxr6turbo.com/forum/topic/88026-fitting-ba-turbo-to-g6et/#findComment-1466322 Share on other sites More sharing options...
