Gremlins In Daughters 2005 Ba Xr6
01txr
  • Replies 34
  • Member For: 11y 3m 11d
I meant one of those silly earth straps that hang of the rear of the car to stop your dog getting car sick(wtf??). I have my reservations about them.
And I'm not sure why you think your flasher unit is controlling your throttle body? Have you been able to scan it for any codes?
  • Member For: 18y 1m 17d
Reason being why I'm thinking the flasher unit is involved is because everything is flashing and on off like as if its running through a flasher unit.
Eg. Leave key on position and all cabin lights 2 rear, 2 footwell and cabin light since bulb replaced is flashing.
Plus the throttle body drive by wire is clucking on off.
Turn light switch to auto and the amp starts clicking, now that's weird as I've never heard a amp click. It is amp as I disconnected it and it stopped clicking.
Then push the door lock on key fob and the indicator lights on dash flash but very dim and indicators are not lighting.
To only way to stop the cluster indicator lights from flashing is to turn headlights on then off.
It seems rediculess to be flasher unit but it was a thought due to the sh*t it's doing.
Car will not lock either.
Yet the boot release works perfectly with key fob and dash button as well the fuel flap release with dash button.
These are the two only things that seem unaffected and working fine.
Also the cabin lights go from dim to flashing to bright in sync with cluster lighting.
Update.
Changed engine earth strap and fitted my near new starter from my xr6t.
Still no change.
However after doing earth strap I got the door locks to work a few times then back to usual.
Next to remove the fuse box and check the earth circuit. Or buy 2 leads to run from battery neg terminal to body and engine.
Or get one of those car earthing kits with numerous earths.
All seems to much as the dam thing should be fine with what it was engineered with. As it was prior.
  • Moar Powar Babeh
  • Member For: 19y 5m 8d
I still maintain they are all functions of the BEM that are acting erratically due to a poor battery.
As Aaron said above, put a volt meter on the battery and try and crank the car.
If you had a short large enough to draw all the starting current from the battery you would have had a fire by now.
That is true Ralph but it doesn't have to be a dead short, I believe this is the 2nd battery he has had whilst trying to rectify the problem. Could be draining slowly over time which intern makes everything play up like you say.
+2 on checking the battery voltage under different load conditions though. They can often meter at 13v ish then the ass just falls out of them as soon as you crank or even just turn the lights on.
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 2m 15d
Check the headlight switch stalk wiring they can cause all sorts of dramas. The stalk cover pulls apart and you can see the dodgy wiring
Edited by SuckSqueezeBangBlow
The battery is not going flat.
But I will check voltage drop tomorrow.
As stated also had a 2nd battery plus jump to a 4wd drive battery plus another car.
Heard about the indicator stalk wiring.
That may be a possibility as maybe if the indicator power wires are shorting it would probably cause the dramas but why has it not shorted the indicator fuse?
I'll check it anyway as that was the first sign of weird sh*t with the flicking of low to high making all the cluster lights light up while flicking the stalk.
Didn't think much more of it as it stopped doing it.
