  • Member For: 11y 5m 6d
^^^ yeah n/a has m80 vs m86 so swap diffs unless you want a weak single pegger. And no real need to swap ecu's and what not just dropping your tune in should do(will have to return your old ecu to stock, unlock xcal ect). There is a thread on a na g6 (not e...) to turbo 6 spd manual thread using a written off fg xr6 turbo. Ill have a dig. I was gonna suggest it when I saw your post in WPYO.
Edited by barnz
Well I wish I had read this thread properly before posting and I wish I could edit my posts but cant for some reason. So sorry about the tripple post
Mcmatty had already mentioned the build I posted a link to and you have posted in that thread lol.
You will need to change the ecu as others have already mentioned and also the engine bay loom. And you will need fraud to sort it all out for you.
Edited by barnz
  • Spooling Member
  • Member For: 13y 4m 20d
Would this be the same if I bought a g6e turbo?
I was hoping to retain the reverse sensors/dual climate etc with the g6e ICC
If you buy a g6e turbo all you would need is your bolt on's and tune, each carbis slightly diff so a dyno tune is probably a good idea. Its just na to turbo that is alot of work. Even a g6e na would Mary up with your turbo ecu with fords help and changing the engine bay wiring.
  • MattyP
  • Cruise Control
  • Member For: 12y 11m 22d
Sounds like the easiest option is to buy another T, swap your mods over and just to part out the wreck and get another tune
  • Spooling Member
Alright sounds like that will be the go then, as far as a dyno tune, should my current tune flashed to the new ecu not work the same with all the same running gear? Or can the body throw something out?
Ratter could explain it better but its basically the same reason generic tune is no good. Even though you would be using the same bolt on parts theres no guarantee two given engines perform identically. So maybe flash your tune to get it running then get it touched up. Dont know if unlocking the xcal wipes any stored tunes though?
