Ford Bf Mkii Xr6 Turbo
xr6tnv
  • PC LOAD LETTER
  • Member For: 13y 1m 3d
Jumped under the car to check a few things this arvo.
Checked diff bush for any outer wear on the main bush and not sure if I have stumbled across a changed diff bush buy the previous owner... what leads me to think this is... there is a redish / amber cap over the bushing, is that normal?? Also the tail shaft leading to the diff has marked lines like it has been removed before. Is any of this from factory and does it look like the diff bushing has one of those aftermarket caps on it to fill the void ?
Then to confirm that the bf has a 19mm rear swaybar.
Also put on a boot mat to make it look a little cleaner.
  • PC LOAD LETTER
The 6 stacker works fine but I'm getting sick of burning music to cd's so decided to buy a new headunit and throw songs on a usb.
  • PC LOAD LETTER
Yeah that's what I thought ! I remember seeing nolathane ones that slot in between the factory bushing for more support ??
  • 2 weeks later...
  • PC LOAD LETTER
Ordered a wiring harness for the headunit along with the fascia... looking at the kit makes it seem like it should be a fairly easy install.
  • PC LOAD LETTER
Damn ! Never thought about the fade control and signal noise :ermm:
Glad you mentioned that though cause at least if it does happen then I know it's fairly normal. I will be glad though when I can use by usb for music than burning more god damn cd's
  • 5 weeks later...
  • PC LOAD LETTER
Nothing much has been happening lately but now with some free time it's installing the head unit and rear sway bar links...
This morning thinking that this should only be an hour n half job which it is turned out to get a bit annoying at points. Taking the console surrounds out was easy and so was a lot of the other things such as running the wires to the fused panel and head unit.
It became an issue when we tried to push the head unit and fascia back into the tissue box area, I'm not sure if it was just my circumstance or the brackets were the wrong way around but they fowled at the back near a foot well vent.
So took a little off the brackets to make that fit and then fiddled with the wires at the back to make sure it all cleared. Also placed the bluetooth mic near the driver side tweeter and ran the wire under the dash mat and pushed the remaining cord behind the side of the icc.
Then came the point where the unit was about 80% back in and connected up... so turned it on which worked but all the sound was coming out very muddy and sounded like the sub wasn't working... Came inside and did a search while having lunch and couldn't find any common errors. Then went back to the car and played with as many settings as I could with nothing really working. Then the old man saw in the headunit manual and option for sub / speakers or sub/sub and speaker/speaker... Sure enough after changing it to speaker / speaker it worked !
Overall very impressed with the quality so far ! I've set it to a high limit of volume on the head unit and then adjust the bass and volume through the icc. No distorting so far but haven't been on the road with it working yet.
