  • New Member
  • Member For: 12y 4m 7d
Hi all, I just my car back after my second ZF catastrophe.
The car is surging under part throttle, by surging I mean the revs are rising and dropping a few hundred rpm as I accelerate off boost. Even with cruise control its quite pronounced. I have an engine light for an O2 sensor which I have replaced as well as the o2 loom to no avail.
I have sprayed Conyact cleaner through the plenum and reflashed the ecu and even rewored my throttle body.
The car has a new stage 2 BTA ZF box and heavy duty std lockup torque converter.
running a process west plenum,kit.
Please help, anybody had this issue?
also I might add that on full bost the car runs 100% but runs super rich when I let off. To the pointbwhere I can see the black fuel smoke while im at the lights
  • 2 weeks later...
  • Member For: 12y 7m 29d
possibly dropped a cam chain guide and jumped a tooth on the crank sprocket... putting you out half a tooth at the cams...
check your cam timing...
let me know.
cheers
  • Spooling Member
  • Member For: 13y 4m 24d
+1 with Kosij
Rev hunting is a possible symptom of ZF milkshake if you don't have an external trans cooler.
I'd check you coolant overflow tank for colour and substance
