Suitable External Fuel Pump For Ba Barra Turbo?
  • Member For: 12y 4m 20d
What is a suitable external fuel pump to use with a Barra turbo from a BA?
I'm doing an engine conversion into a Nissan Patrol, and I think it will be easier to run an inline external pump.
Should I use a surge tank too? Out of interest, are the stock fuel pumps (N/A vs. turbo) the same pump, or are they different?
I'm planning on staying under 300kw. Also, what is the maximum safe limit for a tune on a stock motor with a 3 inch exhaust and bigger intercooler?
  • Forged Member
  • Member For: 17y 9m 10d
you could probably just use an 040 - smaller version of the 044 I believe. Considering the offroad work you are doing I think it would be a good idea to fit a small surge tank even if it is only a 1L capacity
  • Member For: 11y 19d
The 040 is an internal pump, 044 is external.
If your staying low power, maybe an 070 will do? It's a vl turbo pump, I used one with a mechanical lift pump and surge tank in my jackaroo with a Expensive Daewoo 5.0l conversion
