  • MattyP
  • Cruise Control
  • Member For: 12y 11m 18d
Spec up your on hta
A .7 cover and 66mm 7+7 billet wheel sounds unreal
  • billet turbos and weathered engines dont mix
Been seriously looking into this... The other plus about keeping a slightly larger size turbo is I can drive off boost unlike my fg. Plus that sound aww baby.
Look up the 3794 on an xr6 Matty, if the 82 and 86 sound anything like that I'll get one tomorrow. I don't think many people use the HTA because relay vilify was an issue a few years ago and they are hard to get, people can just go guy a GTX. But from what ive read the HTA seems to do what the GTX does only better and has been doing it longer. similar peak power but better spool
  • MattyP
  • Cruise Control
Yeah I've seen that
Sounds unbelievable
From what I've seen you can make your own similar HTA specd 35r
I believe monsta torque in WA make a similar turbo
All you need is the billet T04Z compressor wheel and a housing machined to accept the wheel
Maddd.
For the record, the hta:
3582 is a 68lb flowing turbo
3586 is a 75lb
3794 is a 90lb
Look up forced performance, all the info you need is there
  • MattyP
  • Cruise Control
the 7+7 66mm compressor wheel flows 75lb from what I can tell from the style of wheel im looking at
  • MattyP
  • Cruise Control
Does the 0.7 cover still need machining?
Definitely be a sick setup, would suit what I want to as the 7 blade seem to be more happy with moderate boost, it's kind of a waste with me having the 11 blade, they seem to love the 20lb plus applications
