Stazza_Brendan Donating Members 686 Member For: 15y 6m 5d Gender: Male Location: Mackay QLD Posted 18/04/14 07:10 AM Share Posted 18/04/14 07:10 AM No I had the stock actuator on with the previous setup.For now im running straight from compressor housing to the actuator bypassing the boost controller. 12psi actuator.Pulled the actuator off and lengthened the rod to the right length. Got boost to sit at 15psi using the overboost valve on a softer setting.This will do until I fit the new injectors, valve springs and get a tune. Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1466174 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 20d Gender: Male Location: @ my laptop Posted 18/04/14 07:13 AM Share Posted 18/04/14 07:13 AM you may need a bigger port job Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1466175 Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 15y 6m 5d Gender: Male Location: Mackay QLD Posted 18/04/14 07:48 AM Share Posted 18/04/14 07:48 AM Just how big can you go?Its already got a 32mm port with 37mm flapper 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1466191 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 20d Gender: Male Location: @ my laptop Posted 18/04/14 07:56 AM Share Posted 18/04/14 07:56 AM we've gone bigger than that but a lot depends on the casting, but there is more to a good port job than just the size, we did a car a while back that was tuned in Sydney to 18 psi but on a cold night was getting 23 psi even after it had been ported, we removed the GTX and did our own port job and now it holds at 18.5 on a cold night, apparently the owner heard the overboost valve go off once on a very cold night at 19 psi at high revs after a long pull in 5th gear 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1466192 Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 15y 6m 5d Gender: Male Location: Mackay QLD Posted 18/04/14 08:17 AM Share Posted 18/04/14 08:17 AM So you do porting? Might have to send the housing down to you to play with. Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1466193 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 20d Gender: Male Location: @ my laptop Posted 18/04/14 11:32 AM Share Posted 18/04/14 11:32 AM yeah I do my own but there are plenty of people that do a good job, most turbo shops just seem to make a larger hole and fit the larger flapper, they can work in many cases but not all cases, it is normally only an issue if trying to keep the boost at lower levels, if can only get down to say 16 psi with control but you end up wanting to run 18 psi you do not need to go any more flow 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1466251 Share on other sites More sharing options...
SeduceG6Et67 Member 67 Member For: 11y 3m 3d Gender: Male Location: Perth Posted 07/05/14 01:10 AM Share Posted 07/05/14 01:10 AM Got the Pte 6235 on. Really happy with the result, how it drives, sounds and how it pulls hard right up to redline. Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1469951 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 7m 28d Gender: Male Location: Zombie Birdhouse Posted 07/05/14 01:46 AM Share Posted 07/05/14 01:46 AM Looks like a good base to have started with. Plenty of time of Dyno time spent on this car overall.Shows some love has gone into it.Appears to be a nice tune. Do you have AFRs/Lambda Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1469954 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 12d Gender: Male Location: Central Coast Posted 07/05/14 02:03 AM Share Posted 07/05/14 02:03 AM I'm glad it shows the comparison between the two so you can really see how punchy the stock turbo is Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1469968 Share on other sites More sharing options...
SeduceG6Et67 Member 67 Member For: 11y 3m 3d Gender: Male Location: Perth Posted 07/05/14 02:40 AM Share Posted 07/05/14 02:40 AM (edited) On 07/05/2014 at 2:03 AM, McMattyP91 said: I'm glad it shows the comparison between the two so you can really see how punchy the stock turbo isIt doesn't feel much different to the stock one low down our not that I can tell and Simon said the same with the torque. I don't know all the technical stuff too much...what are AFR's,oh and while I'm asking I see WOT thrown around, what is that. Thanks. I'll upload a PIC of the turbo. Edited 07/05/14 02:42 AM by SeduceG6Et67 Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/7/#findComment-1469981 Share on other sites More sharing options...
