old_mate Member 767 Member For: 19y 2m 3d Gender: Male Location: Brisbane Posted 31/03/14 10:44 AM Share Posted 31/03/14 10:44 AM Ill be doing E85 before racing you again beau just in case you get your squirrel on. Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1462944 Share on other sites More sharing options...
hoarspower Member 478 Member For: 13y 7m 4d Gender: Male Location: brisbane Posted 31/03/14 10:57 AM Share Posted 31/03/14 10:57 AM have e85 and a lil som something coming REAl soon Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1462946 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 20d Gender: Male Location: Perth Posted 31/03/14 03:01 PM Share Posted 31/03/14 03:01 PM On 31/03/2014 at 8:40 AM, SeduceG6Et said: Just got back from Xtreme. Simon was busy so I spoke to Shaun. Anyway,I have been quoted 6500 for race air box,battery relocate,valve springs,surge with twin fuel pumps and GTX3582. Shaun went and asked Simon how much for the Precision. He said 3000 on top but its not the 6235 its one they use not sure which one but its a lot of work to get it on. He said they do another one which is easier. I said is it the 6235.....hes not sure but he will call me tomorrow. I expected more but $6500 before now $9500. Doesnt seem right. I hope he gets back to me and says the 6235 is cheaper than that. Going by what people are saying the GTX3576 might be the better choice. So the GTX3576 is better than the standard FG F6 turbo. I like the quick spool but want a bit more up top.Small turbo wont go near F6 turbo unless its on E85.Do you want E85? Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1462957 Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 15y 6m 5d Gender: Male Location: Mackay QLD Posted 31/03/14 08:25 PM Share Posted 31/03/14 08:25 PM 397kw on 20psi tapering to 18psi on 98 octane.425kw on 25psi tapering to 20psi on 98 octane.This was achieved using a gtx3576r on a 1.06(ford) rear housing.The same car had previously ran the f6 turbo and made 430kw. Not much difference in the peak number. But response, low down torque was superior on the baby gtx. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1462966 Share on other sites More sharing options...
sixman Donating Members 601 Member For: 20y 8m 25d Gender: Male Location: Hills District, NSW Posted 31/03/14 09:52 PM Share Posted 31/03/14 09:52 PM Stazza, what boost was the f6 turbo running?Very impressive numbers from the little GTX!I imagine that car was a real weapon Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1462968 Share on other sites More sharing options...
RynoF6 Idiot Member Donating Members 446 Member For: 15y 2m 26d Gender: Male Location: Muswellbrook, NSW Posted 01/04/14 01:15 AM Share Posted 01/04/14 01:15 AM Spool is over rated. That vid looks like just wheelspin city. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1462990 Share on other sites More sharing options...
SeduceG6Et Member 26 Member For: 12y 3m 8d Gender: Male Location: Perth Posted 05/04/14 09:56 AM Author Share Posted 05/04/14 09:56 AM Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1463691 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 5m 28d Posted 05/04/14 10:20 AM Share Posted 05/04/14 10:20 AM Very good results have been seen with the 6235. Comparatively to the gtx3582 it comes on earlier and hits higher peak power, from the testing I've seen 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1463696 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 12d Gender: Male Location: Central Coast Posted 05/04/14 11:37 AM Share Posted 05/04/14 11:37 AM The 6235 seems to be the go atmBut like has been said before If it's a daily or you do long trips You will miss the response of the standard turbo Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1463709 Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 15y 6m 5d Gender: Male Location: Mackay QLD Posted 09/04/14 03:03 AM Share Posted 09/04/14 03:03 AM Got home from night shift, straight into the car to pick up turbo from couriers.Came with the housing already bolted on the rear.Tested the retaining plate for the compressor cover against the stock B series wastegate bracket.Winner, exact same pattern.Bolted on with stock actuator (turbosmart one hasn't arrived yet) and it all lines up.(Core has to be rotated to correct position)4inch joiner onComparison time..Beside a stock B series turbo (gt3582r)Rear housings, .82 on the left and stock ford 1.06 on right, camera angle makes the .82 look smaller then it is but you can definately tell its smaller then the ford housing. Rear flange is the same size.Top down view of the .82 on left and Ford 1.06 on right. .82 is smaller looking from the rear but looking down from the top its about the same width as the Ford housing.Comparing the common rear housing sizes.Left- externally gated .63 housingMiddle- Internally gated .82 housing (what ill be running)Right- Stock internally gated 1.06 housingComparing the wastegate sizes. The flap on the new .82 housing is 37mm with a 31-32mm port. This compares to the fords small 33mm flap with 25mm port. Looks like I get away without having to send the new housing away for a port job.Bigger port from factory plus nizpro overboost valve should control boost spikes.Just waiting for the turbosmart actuator to show up then ill be bolting the thing in. Just run on spring pressure (12psi) and watch my wideband gauge while taking it easy till I get a tune. I should be able to tell if the .82 housing is too small before getting a tune. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87866-gtx3582-or-gtx3576-on-a-g6et/page/5/#findComment-1464469 Share on other sites More sharing options...
