How To Replace Radiator Support Fg F6 2009?
Knackers
  • Member For: 14y 16d
I had the F6 in a thousand pieces today trying to fit a saggy front bar after collecting a serious spoon drain.
I knew I was up for bar mounts LH and RH and lost a few scrivets but that's all sorted.
I have found a completely shattered radiator support bar - its broken in 3 places. and whole 6" section on the LHS that ties to the fender is completely missing and I've discovered a bit of dodgy repair work...lots of sikaflex....LOTS of sikaflex
So someones done the dodgy and had a crack at repairing it themselves and left me with a problem - I can't install my new cooler till the rad-support is replaced.
How does this thing come out? is seems to be fused to the metal upper support (where the striker etc attaches) but the whole rad-support is made of a hard plastic.
I would like to do it myself to save the $$$ it will cost to get a crash repairer to do it, I don't wish to make an insurance claim either. But after pricing the parts, its looking bad ($455 rad-support, $300ea for headlights...the list goes on)
Has anyone here ever done it? care to share?
thanks in advance.
  • Dropping a turd
  • Member For: 17y 3m 20d
The joys of second hand cars. Hope it works out for you. Just have to bite the bullet and get it fixed properly.
  • Dropping a turd
Iam not sure, you need to seek a professional opinion, if its expensive claim insurance. BUT its a prior bad repair so they may reject the claim.
  • XR50T
  • Member For: 11y 9m 15d
If your going with a bigger cooler the PW stage 3 kit has it's own radiator mounts to step it back and make more room for the cooler.
^ already got the cooler, was supposed to put it in yesterday while the bumper was off, but then I found the mess behind the bar. Got my new rad support today. When I get time to fit it I'll take a few photos and notes for reference should anyone else need it, there is nothing online to assist anyone trying this them self.
  • Member For: 13y 10m 28d
FG radiator supports are combination plastic/metal item. They are spot welded and Mig welded on the skirts and bolted on using large self tapping 12mm bolts through the lower skirts. As a guide your probably looking at around $400 to strip the front end and replace the support plus parts/paint.
