Bulletime Donating Members 937 Member For: 14y 5m 11d Gender: Male Posted 17/04/14 12:21 PM Share Posted 17/04/14 12:21 PM Mine got done by a proper transmission shop and it took a full liter to fill, done at the right temp. All up 943, about 180 for install and fluid top up and I just got them to order the pwr exchanger. Seen some guys payin 700-800 for oil to air. Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466056 Share on other sites More sharing options...
VippiN Member 94 Member For: 16y 5m 13d Gender: Male Location: Adelaide, Australia Posted 18/04/14 12:15 AM Share Posted 18/04/14 12:15 AM I was dead set on getting a heat exchanger but called Bruce Heinrich and was talked out of it for a trans cooler. Going to go with his advice and get the cooler installed. They said they've been installing them for a long time and on race falcons too and never had one come back with an issue. Was good enough for me, and cheaper too. Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466091 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 2m 9d Posted 20/04/14 02:26 AM Share Posted 20/04/14 02:26 AM for those who got the PWR kit, have you noticed an increase in trans temps?ive been keeping an eye on mine and it hardly ever hit 100deg with the stock heat exchanger (mostly 90 to 98ish even in summer)but since switching to PWR recently, ive noticed temps are higher by around 10 degrees. I managed to hit 105deg with a few squirts and some highway driving the other night and the weather wasn't warm eitherim using the torque app to monitor temps for both the stock and PWR heat exchanger and haven't changed any settings on that Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466539 Share on other sites More sharing options...
VippiN Member 94 Member For: 16y 5m 13d Gender: Male Location: Adelaide, Australia Posted 21/04/14 01:25 AM Share Posted 21/04/14 01:25 AM From reading on fordforums it's meant to drop temps by around 10c Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466707 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 2m 9d Posted 21/04/14 11:46 AM Share Posted 21/04/14 11:46 AM Yeah I know. There was even another guy here that datalogged the pwr unit and stock heatexchanger back to back using the same app I'm using for temps.I suspected I'd lost a fair bit of coolant when the pwr kit was installed and when I changed my thermostat a few months back so I've been topping up with more concentrate.Since then trans temps have gone a bit lower but not by much. Last run today it hit 102deg after some short bursts and a bit of traffic then dropped back to around 98deg then slowly back up to 100deg constant after cruising it when I got on the highway Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466817 Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 10m 26d Gender: Male Location: Perth Posted 21/04/14 09:20 PM Share Posted 21/04/14 09:20 PM Changed your thermostat to an 82deg?I would be checking your water lines for kinks to the transcooler.My ute runs an Alfa Lavel transcooler, sits between 85 and 95deg C.Cruising at 85deg C. Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466857 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 2m 9d Posted 21/04/14 11:28 PM Share Posted 21/04/14 11:28 PM No just a standard thermostat. Will have to get under the car to check the lines but all seemed OK when CMS did the install. I watched them do the entire install and refillDoes anyone else with a PWR kit know what temps theirs sits at when up to full temp? Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466871 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 24d Gender: Male Location: @ my laptop Posted 21/04/14 11:33 PM Share Posted 21/04/14 11:33 PM are you monitoring your coolant temps as well? Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466873 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 2m 9d Posted 21/04/14 11:47 PM Share Posted 21/04/14 11:47 PM I normally use the water gauge on the dash but will also make a gauge in torque so I can get an exact temp.Off the dash water gauge it sat just above the notch to the left of the halfway marker, same as stock.But I did notice the water temp rose slightly yesterday when it hit 105deg and also went down when the trans temp droppedCould it still be the coolant mix ratio isn't quite right? Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466877 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 24d Gender: Male Location: @ my laptop Posted 21/04/14 11:53 PM Share Posted 21/04/14 11:53 PM trans temp will have a lot to do with coolant temp. Link to comment https://www.fordxr6turbo.com/forum/topic/87822-pwr-heat-exchanger-or-air-to-air-in-zf/page/7/#findComment-1466880 Share on other sites More sharing options...
