RIP85 REST IN PEACE V8 Donating Members 469 Member For: 17y 21d Gender: Male Location: Woodridge on the park bench Posted 25/03/14 12:30 PM Share Posted 25/03/14 12:30 PM Had same issue 747 but with gtx35/82 the flapper would open and tapper the boost back to 16psi as u can see by the dyno graph problem was solved with eboost2 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1461995 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 15d Gender: Male Location: @ my laptop Posted 25/03/14 11:05 PM Share Posted 25/03/14 11:05 PM 76 is different to 82, does not flow as much air, eboost2 should do exactly the same thing as factory controller in that situation Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1462039 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 9m 2d Gender: Male Posted 26/03/14 05:37 AM Share Posted 26/03/14 05:37 AM By saying eboost fixed it your saying your standard boost solineiod was stuffed! In other words your tuner was lazy. Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1462136 Share on other sites More sharing options...
RIP85 REST IN PEACE V8 Donating Members 469 Member For: 17y 21d Gender: Male Location: Woodridge on the park bench Posted 27/03/14 11:19 AM Share Posted 27/03/14 11:19 AM (edited) On 25/03/2014 at 11:05 PM, ratter said: 76 is different to 82, does not flow as much air, eboost2 should do exactly the same thing as factory controller in that situationNot if you have a the eboost 2 connected to an rpm signal when it starts to tapper off adjust as necessary only gained two psi so ditched whole setup but you are probably right on a 76tuner wasn't lazy nothing wrong with my solineiod atomic 4+plus cams and head porting try holding more than 16psi with an internal gate we got 18psi due to rpm pickup with the eboost Edited 27/03/14 11:22 AM by RIP85 Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1462399 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 15d Gender: Male Location: @ my laptop Posted 27/03/14 11:35 AM Share Posted 27/03/14 11:35 AM The factory controler does that also 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1462400 Share on other sites More sharing options...
RIP85 REST IN PEACE V8 Donating Members 469 Member For: 17y 21d Gender: Male Location: Woodridge on the park bench Posted 27/03/14 12:44 PM Share Posted 27/03/14 12:44 PM On 27/03/2014 at 11:35 AM, ratter said: The factory controler does that alsoreally so when the boost tappers off due to the flapper opening you can force it to stay closed at a certain rev to hold the flapper shut Thanks I never new factory controller could do that 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1462412 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 15d Gender: Male Location: @ my laptop Posted 27/03/14 06:37 PM Share Posted 27/03/14 06:37 PM Yes mate, the eboost has some extra features but operates the same as the factory controler Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1462428 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 26d Gender: Male Posted 29/03/14 04:30 AM Share Posted 29/03/14 04:30 AM e-boost is good if you don't want to change tunes, my car ramps in boost gradually for street duties, but when I turn on the e-boost boost comes in hard at 25-26 psi and then tappers off.Maybe my tuner was lazy............ Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1462626 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 15d Gender: Male Location: @ my laptop Posted 29/03/14 05:23 AM Share Posted 29/03/14 05:23 AM no boost controller can cover any mechanical mismatch, sometimes there is just not enough hardware to do what is asked 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1462628 Share on other sites More sharing options...
RIP85 REST IN PEACE V8 Donating Members 469 Member For: 17y 21d Gender: Male Location: Woodridge on the park bench Posted 29/03/14 10:56 PM Share Posted 29/03/14 10:56 PM we gave up on mine went external gate solved the actuator problem. Still think e boost is a good idea trying to convince my tuner to allow me to run a solenoid as such which will allow me to run say 10psi up two 100ks then full boost after that using the eboost instead of having to push the plus and minus Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/7/#findComment-1462698 Share on other sites More sharing options...
