Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 9m 11d Gender: Male Location: Adelaide Posted 23/03/14 01:01 AM Share Posted 23/03/14 01:01 AM should have got the 3582. Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461439 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 2m 6d Gender: Male Posted 23/03/14 01:01 AM Author Share Posted 23/03/14 01:01 AM My understanding is that mechanically it should be able to flow more than 16psi and just make no power due to heat generation/no more air volume if pushed past it's effiencey ? Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461440 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 12y 11m 25d Gender: Male Location: Wollongong Posted 23/03/14 01:06 AM Share Posted 23/03/14 01:06 AM There's something wrong with your setup somewhere if it's not pushing past 16, these turbos can in theory do 35+ . Check everything again, a GTX is only jussstttt coming into its efficiency range at 16, they really start to shine at 20-23. Something is restricting the turbo wether it be intake/exhaust or the engine can't handle it ie valve springs even though you changed them. Even your tune? Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461441 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 2m 6d Gender: Male Posted 23/03/14 01:08 AM Author Share Posted 23/03/14 01:08 AM To be honest I purchased it under the impression it was the 3582. Mind you as said, for someone chasing something relatively safe on a standard motor and gearbox it really moves, easily blazes first 3 gears in the dry and has spun in 4th if loaded up. Looks like I'll be selling a complete standard FG turbo with 20,000km and the above gtx3576 complete with ported housing and turbosmart gate Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461443 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 2m 6d Gender: Male Posted 23/03/14 01:11 AM Author Share Posted 23/03/14 01:11 AM Hmmm exhaust and intake setup are brand new, the valve springs are supposed to be the tits and are also brand new ? The turbo can't create more than 16psi even with the gate held shut Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461445 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 12y 11m 25d Gender: Male Location: Wollongong Posted 23/03/14 01:14 AM Share Posted 23/03/14 01:14 AM Wait you have the gtx3582 or 3576? The '76 wil run out of puff at about 400rwkw, but that's still easily over 20psi, where the 82 can keep going. Don't sell it man they're a perfectly matched turbo for our cars. Where are you located? Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461446 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 12y 11m 25d Gender: Male Location: Wollongong Posted 23/03/14 01:16 AM Share Posted 23/03/14 01:16 AM On 23/03/2014 at 1:11 AM, 747pwr said: Hmmm exhaust and intake setup are brand new, the valve springs are supposed to be the tits and are also brand new ? The turbo can't create more than 16psi even with the gate held shutNot saying your lying, it's just they're has to be a problem that you just haven't found yet because it's a proven combo 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461447 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 2m 6d Gender: Male Posted 23/03/14 01:17 AM Author Share Posted 23/03/14 01:17 AM I'm pretty confident it's the gtx3576 because it's got the 0.6 front cover. Yeah currently makes 470rwhp through the ZF. Located in Far North Queensland. The current tune is 20psi but it tapers to 16psi at like 4000/4500rpm Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461448 Share on other sites More sharing options...
747pwr Member 68 Member For: 14y 2m 6d Gender: Male Posted 23/03/14 01:22 AM Author Share Posted 23/03/14 01:22 AM I understand that Ma9ick, I hope there is something wrong so we can squeeze some more power out ! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461450 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 12y 11m 25d Gender: Male Location: Wollongong Posted 23/03/14 01:23 AM Share Posted 23/03/14 01:23 AM Id say so mate. If that's the case then you MAY have a dodgy turbo, could still be the tune though or just unlucky and got a dud set of springs. You'll have to wait till the experienced guys chime in, I still only have relatively limited knkwledge Link to comment https://www.fordxr6turbo.com/forum/topic/87815-gtx-wont-hold-or-increase-boost/page/2/#findComment-1461451 Share on other sites More sharing options...
