xr6tee9 Member 82 Member For: 11y 15d Gender: Male Location: adelaide Posted 12/03/14 12:47 PM Share Posted 12/03/14 12:47 PM (edited) gday all, not really sure where to post this but im having a problem that is really beginning to annoy me.. xr6t bf2 seems to have a slight popping through exhaust in park at about 2200 to 2500rpm.. in drive under light acceleration it happens at precisely 1250rpm and is heard as a slight rumble through exhaust and a sluggish spot.. if I can hold it @ those rpm the tacho fluctuates approx 200rpm with speed staying same.. approx 60kmh.. but is hard to hold there with 6 speed zf in triptronic mode wanting to change gear at that speed.. from a standing start car performs great, boosts up, breaks traction etc, but from a rolling start around said speed it is sluugish then boosts up, surges, drops then surges again.. not sure but seems to be on gear change, does it with traction on or off.. I was thinking coils to start with but then they usually break down at higher rpm, plug gaps maybe? or wastegate?? no leaks in intercooler piping, throttle body could need a clean but was done about 6 months ago..low rpm- could it be vct.?im heading to see bruce in next week or 2 as it also has a 2 sec rattle at start up.. possibly chain guides.. Edited 12/03/14 12:50 PM by xr6tee9 Link to comment Share on other sites More sharing options...
xr6tee9 Member 82 Member For: 11y 15d Gender: Male Location: adelaide Posted 13/03/14 09:09 PM Author Share Posted 13/03/14 09:09 PM I guess nobody has any input or idea...? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 21d Gender: Male Location: Perth Posted 14/03/14 01:02 AM Share Posted 14/03/14 01:02 AM Are you running Siemens Deka's by any chance? Link to comment Share on other sites More sharing options...
xr6tee9 Member 82 Member For: 11y 15d Gender: Male Location: adelaide Posted 14/03/14 06:18 AM Author Share Posted 14/03/14 06:18 AM im not sure ralf, bruce supplied and fitted injectors.. receipt just says.. supply and fit hi flow injectors.. xcal2 doesnt show any codes?? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 21d Gender: Male Location: Perth Posted 14/03/14 06:38 AM Share Posted 14/03/14 06:38 AM Post up a pic of the injectors Link to comment Share on other sites More sharing options...
xr6tee9 Member 82 Member For: 11y 15d Gender: Male Location: adelaide Posted 14/03/14 06:51 AM Author Share Posted 14/03/14 06:51 AM heres is some numbers I found on them.. previous to bruce changing it had 42lb injectors.. numbers are 3R23AA one side, 0280156128 other side, at top fuel rail is 806.. colour is blue Link to comment Share on other sites More sharing options...
xr6tee9 Member 82 Member For: 11y 15d Gender: Male Location: adelaide Posted 14/03/14 08:30 AM Author Share Posted 14/03/14 08:30 AM Well my research doesnt find this partno. But it does find it ending in a 3.. which seems to be standard injectors.. wtf..!Correct me if im wrong..Will be contacting bruce if this is indeed the case.. Link to comment Share on other sites More sharing options...
DD-XR-6T Member 134 Member For: 11y 10m 19d Gender: Male Location: Sydney/Canberra Posted 16/03/14 04:59 AM Share Posted 16/03/14 04:59 AM heres is some numbers I found on them.. previous to bruce changing it had 42lb injectors.. numbers are 3R23AA one side, 0280156128 other side, at top fuel rail is 806.. colour is blueYeah mate they're the standard ones alright codes match up to the ones I pulled out of mine ages ago. Sounds like he downgraded you and charged ya thinking you wouldn't know any better. The previous ones you had woulda been out of an F6 if they were 42lb. They also would have been greenStandard ones are about 20lb Link to comment Share on other sites More sharing options...
xr6tee9 Member 82 Member For: 11y 15d Gender: Male Location: adelaide Posted 16/03/14 05:36 AM Author Share Posted 16/03/14 05:36 AM I suppose it is possible he has fitted redrilled/reflowed units.. ringing him tomorrow.. I have a dyno sheet for 369.8rwkw which contradicts they are standard..?? Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 6m 8d Gender: Male Location: Adelaide Posted 16/03/14 05:44 AM Share Posted 16/03/14 05:44 AM pic of dyno Link to comment Share on other sites More sharing options...
