  • Member For: 11y 5m
Mate as a qualified sparky and working specifically in the field of electronics I can tell you reco electronics is bullsh*t, few people have the skills to properly fault find them as most things just get replaced these days, and it's not really cost effective to do so. Perhaps they spotted some dry solder joins or something of the like and fixed that up, which could damage something else depending on the heat applied. Realistically do you think old mate knows exactly how the ford ecu works and sat down found the problem and replaced a chip or something(which requires special tools). Impossible no, but unlikely.
Could always grab an ecu from a wrecker and get ford to program it in. They are pretty pricey new.. But still beats throwing parts at it until you replace the ecu which is exactly what happened in the other thread. The fact you had it "reco'd" and you got all transmissions solenoids popping up in fault which is unlikely, points to the ecu I reckon.
Sent via carrier pigeon
  • Member For: 11y 3m 29d
Why was the computer reconditioned in the first place? Electronics these days are not as serviceable as they used to be, I can't see what exactly would be involved in a recondition (board reflow, new thermal paste?) Opening one up would probably do more damage than good.
  • Member For: 11y 1m 11d
I had the coils & plugs replaced as was running bad & after replaced them it still ran like a barge thought ld done engine damage but found it was computer so it was sent off to be "recoed" was running fine after that...an auto elec looked at car checked it & saw computer had been sent to this place & says he sends work there too & they good l'll get the name of the place maybe people know it
