LU82 Bronze Donating Members 569 Member For: 12y 5m 13d Posted 13/03/14 04:23 AM Share Posted 13/03/14 04:23 AM Cold air intake, high flow exhaust running 7psi on standard tune when it should be 4.5-6. When you take your car in to get your actuator looked at ask the shop if your exhaust and intake is suitable to use with the factory tune. Link to comment https://www.fordxr6turbo.com/forum/topic/87681-wastegate-acutator/page/3/#findComment-1459978 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 18d Gender: Male Location: Brisbane Posted 13/03/14 04:27 AM Share Posted 13/03/14 04:27 AM (edited) ^^^lol @ pingtune. Is your high flow exhaust just cat back or? My cars stock so I don't know for sure but fairly certain an exhaust should be accompanied by a tune, and would be essential if cat&dump are changed or it will overboost.Sent via carrier pigeon Edited 13/03/14 04:28 AM by barnz Link to comment https://www.fordxr6turbo.com/forum/topic/87681-wastegate-acutator/page/3/#findComment-1459979 Share on other sites More sharing options...
casper89 Member 18 Member For: 11y 11m 22d Gender: Male Posted 13/03/14 10:57 AM Author Share Posted 13/03/14 10:57 AM Ended up swapping the TS 7psi wastegate for a 3psi wastegate from Garrett and doing it myself with a mate. It wasn't too hard getting it off, more so getting it the arm to line up properly when fitting the new one. Mad ***** to do but hey, I saved a minimum of $300 so can't complain too much.Cold air intake, high flow exhaust running 7psi on standard tune when it should be 4.5-6. When you take your car in to get your actuator looked at ask the shop if your exhaust and intake is suitable to use with the factory tune.Since replacing the wastegate, it now peaks at 6psi Link to comment https://www.fordxr6turbo.com/forum/topic/87681-wastegate-acutator/page/3/#findComment-1460054 Share on other sites More sharing options...
casper89 Member 18 Member For: 11y 11m 22d Gender: Male Posted 13/03/14 11:04 AM Author Share Posted 13/03/14 11:04 AM ^^^lol @ pingtune. Is your high flow exhaust just cat back or? My cars stock so I don't know for sure but fairly certain an exhaust should be accompanied by a tune, and would be essential if cat&dump are changed or it will overboost.Sent via carrier pigeondump pipe is changed too but not the extractors, it seems to be all good now since replacing the wastegate, I realise a tune would get max performance out of that exhaust but the thing is I can't justify spending over $800 on a cheap plastic device which loads a tune to my car. Yes the kW gain is amazing, yes there are mods which cost lot more money and gives you way less a gain - but seriously it's just so much for what it actually is. In saying that if I had the money I'd definitely do it and enjoy it.I didn't do any of those mods I bought the car like this. The only thing I did was the oil feed line and the BOV and adapter cause the idiot who owned before me got rid of the stock bosch recirculating valve and closed off the ports so the turbo was getting all kinds of crazy surge. The TS adapter and BOV sounds a lot better and I don't have to worry about the turbo conking down the line. Link to comment https://www.fordxr6turbo.com/forum/topic/87681-wastegate-acutator/page/3/#findComment-1460056 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 18d Gender: Male Location: Brisbane Posted 13/03/14 11:20 AM Share Posted 13/03/14 11:20 AM Mate at the end of the day its up to you but everybody is just trying to help you save your engine, stock ba tune is like 6 in the mid and 4ish in the top I think , if your holding 7 it may do damage, and as ratter said, who I believe is a tuner? That actuator is not suited to a ba stock tune. Just cause your not hitting boost cut now doesn't mean it's not lean or something. And a melted engine is going to cost much more than a tune. Atleast spend like 50bucks on an elm27 and see if it's throwing any codes.Sent via carrier pigeon Link to comment https://www.fordxr6turbo.com/forum/topic/87681-wastegate-acutator/page/3/#findComment-1460060 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 7m 18d Gender: Male Location: Brisbane Posted 13/03/14 11:40 AM Share Posted 13/03/14 11:40 AM ^^Sorry just saw u went with the 3 psi so my badSent via carrier pigeon Link to comment https://www.fordxr6turbo.com/forum/topic/87681-wastegate-acutator/page/3/#findComment-1460063 Share on other sites More sharing options...
