bogan247 New Member 6 Member For: 11y 1m 14d Posted 02/03/14 04:21 AM Share Posted 02/03/14 04:21 AM Hey Guys,I've recently come across a problem with having no boost. Gauge says I have good VAC but when I put my foot down it hits 0 on the gauge and stays there. When this is happening all that can be heard is an air rushing noise. I was wondering if anyone else has had similar problems? and where the best place to start would be?Cheers Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 10m 11d Gender: Male Location: Victoria Posted 02/03/14 04:26 AM Share Posted 02/03/14 04:26 AM Sounds like one of the hoses has blown off.Check all the cooler hoses etc from the turbo to the throttle body. 1 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 3m 12d Gender: Male Location: Probably above atmospheric pressure Posted 02/03/14 04:37 AM Share Posted 02/03/14 04:37 AM Best place to start is the turbo. Check you have one...and go from there by checking pipe connections as mentioned Maybe wastegate is stuck wide open? Not sure if you'd see any boost or not in that case. Does the turbo spin OK by hand? 2 Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 8m 7d Gender: Male Posted 02/03/14 06:41 AM Share Posted 02/03/14 06:41 AM Best place to start is the turbo. Check you have oneThis - But more seriously you've most likely blown a hose off the boost reg. tiny barbs on those things Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 2m 1d Gender: Male Location: In my house Posted 02/03/14 07:53 AM Share Posted 02/03/14 07:53 AM Seriously thou, probably a hose off like others have said. I had it happen a few times and funny thing was is that I had one very powerful 450hp leaf blower. 1 Link to comment Share on other sites More sharing options...
bogan247 New Member 6 Member For: 11y 1m 14d Posted 02/03/14 08:47 AM Author Share Posted 02/03/14 08:47 AM Checked for turbo. Turbo is there. :o)Cheers for all the feed back guys, will hook into it tomorrow and see what I come up with. 1 Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 7m 14d Gender: Male Location: Maryborough Qld Posted 02/03/14 09:01 AM Share Posted 02/03/14 09:01 AM boost leak for sure Link to comment Share on other sites More sharing options...
bogan247 New Member 6 Member For: 11y 1m 14d Posted 03/03/14 06:22 AM Author Share Posted 03/03/14 06:22 AM (edited) I've just pulled the boost solenoid off. Is there only 2 hoses that run to this? There is a port for another hose but I can't find anything loose.Turbo spins ok by hand. Edited 03/03/14 06:23 AM by bogan247 Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 2m 1d Gender: Male Location: In my house Posted 03/03/14 06:30 AM Share Posted 03/03/14 06:30 AM check all hoses attached to the cooler, Under battery pipe and throttle body. Link to comment Share on other sites More sharing options...
Akidaki New Member 17 Member For: 11y 6m 23d Gender: Male Posted 03/03/14 08:10 AM Share Posted 03/03/14 08:10 AM You could have had a crap batch of fuel, and the computer puts itself into safe mode, and can therefore run with no boost.I have had this issue on a few of my turbo cars over the years.If all your cooler pipe work, and hoses look okay, try taking the negative off the battery for 30 seconds, put your foot on the brake pedal to drain the current, then re-connect.I've done this before, and straight away car was running like new again. Link to comment Share on other sites More sharing options...
