Rydeit Member 327 Member For: 12y 7m 9d Gender: Male Location: Adelaide S.A Posted 26/02/14 06:17 AM Share Posted 26/02/14 06:17 AM Hey guys. Car made 325 rwkw last tune and since then I have changed the standard cooler to a rapid v2 kit and 4" turbo side intake and walbro fuel pump. I have also put a new 35/40 on and done the coil packs and plugs. Had it all retuned today and couldnt make barely any more power. Tuner was shocked until he realized the exhaust was a 3" system. No cat just rear muffler. He then knew why it wasnt making power. I blame the previous owner for going 3" the banana lol. Where do I go from here and what power should I really be making? Is the 3.5 inch better flowing for big power or twin 2.5 inch. Other mods are 7psi actuator and 60lb injectors.Cheers Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 4m Posted 26/02/14 06:34 AM Share Posted 26/02/14 06:34 AM Seen plenty of 3" systems make more than 350rwkw but yet I had the same problem with my factory exhaust holding me back. 3.5 and twin 2.5 are pretty similar, just make sure you're upgrading the dump pipe as well Link to comment Share on other sites More sharing options...
Rydeit Member 327 Member For: 12y 7m 9d Gender: Male Location: Adelaide S.A Posted 26/02/14 06:46 AM Author Share Posted 26/02/14 06:46 AM I was prettty shocked that it restricted that much. I was told that it's the usual case with the 3". Would the std dump pipe be holding me back that much aswell. My mate has twin 2.5 with stock dump and few other mods like external gate and is making 400rwkw through a 4 speed btr 1 Link to comment Share on other sites More sharing options...
Rydeit Member 327 Member For: 12y 7m 9d Gender: Male Location: Adelaide S.A Posted 26/02/14 08:15 AM Author Share Posted 26/02/14 08:15 AM Found a twin 2.5 and 4 inch dump for $500 second hand. Should do the trick. Also has quad tips 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 28d Gender: Male Location: Perth Posted 26/02/14 08:59 AM Share Posted 26/02/14 08:59 AM I was prettty shocked that it restricted that much. I was told that it's the usual case with the 3". Would the std dump pipe be holding me back that much aswell. My mate has twin 2.5 with stock dump and few other mods like external gate and is making 400rwkw through a 4 speed btrExternal gate vented to atmo? Link to comment Share on other sites More sharing options...
Rydeit Member 327 Member For: 12y 7m 9d Gender: Male Location: Adelaide S.A Posted 26/02/14 09:06 AM Author Share Posted 26/02/14 09:06 AM Standard gate on my car but mate I was referring to has external gate. Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 7m 18d Gender: Male Posted 26/02/14 10:01 AM Share Posted 26/02/14 10:01 AM What model are we talking about here? Bxr6t? F series? I've heard the F6 setups rear of the cat actually don't flow too bad for 2.5 setups? Link to comment Share on other sites More sharing options...
Rydeit Member 327 Member For: 12y 7m 9d Gender: Male Location: Adelaide S.A Posted 26/02/14 10:09 AM Author Share Posted 26/02/14 10:09 AM Ba f6 typhoon bud Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 10m 17d Gender: Male Location: Liverpool Posted 26/02/14 06:47 PM Share Posted 26/02/14 06:47 PM My BF mk2 made around the 360rwkw with a hollow cat, changed to the xforce 4" dump with twin 2.5", still in the process of tuning but it lost a lot of torque down low, but breathes a lot better up top.. The force 'works' but If I were to do it again I'd look into the ces racing exhaust or herrods kit or something Link to comment Share on other sites More sharing options...
Rydeit Member 327 Member For: 12y 7m 9d Gender: Male Location: Adelaide S.A Posted 27/02/14 01:48 AM Author Share Posted 27/02/14 01:48 AM Cheers. Useful info mate. Im aiming for around the same power level considering the mods I have. Will opt for basically the same setup you just mentioned in mild steel. Link to comment Share on other sites More sharing options...
