patrol_maverick Member 54 Member For: 12y 7m 15d Gender: Male Location: Taree NSW Posted 24/02/14 11:11 AM Share Posted 24/02/14 11:11 AM (edited) Long story short;I have bought a BA series 1 Barra turbo to put into a Nissan Patrol. I have to get the ECU flashed to make it a stand alone unit. I have been emailing a tuner about the ECU and have been informed that the BA engine is a 'grenade' particularly if you start modifying the exhaust before the cat and don't tune to compensate for it.Is this the case, or is he just trying to sell me a tune? I'm a mechanic and I know there will be issues if it's ridiculously modified without a tune, but how sensative are these engines to minor changes? I thought they were reasonably bullet proof.I won't be thrashing it. I'm building it for offroading and towing, so it needs to be reliable.I plan on running a stock BA engine & turbo, stock tune, and an FG exhaust manifold & dump pipe (due to space restrictions), and most likely a single 3 inch exhaust and probably no cat.So back to my question, Should I be worried about it being a grenade or not? Edited 24/02/14 11:12 AM by patrol_maverick Link to comment Share on other sites More sharing options...
jacobmitchell92 Donating Members 370 Member For: 13y 10m 2d Gender: Male Location: Perth Posted 24/02/14 11:28 AM Share Posted 24/02/14 11:28 AM Will over boost without a cat and then go bang Link to comment Share on other sites More sharing options...
patrol_maverick Member 54 Member For: 12y 7m 15d Gender: Male Location: Taree NSW Posted 24/02/14 11:36 AM Author Share Posted 24/02/14 11:36 AM Why will it overboost without a cat? I thought the boost was ECU controlled via a solenoid. Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 5m 7d Gender: Male Location: Penrith Posted 24/02/14 11:47 AM Share Posted 24/02/14 11:47 AM dont know but it will. A mate put a 100 cell cat on his ba a few days before getting a tune and it was overboosting and going into limp mode. Got a tune and all good. Link to comment Share on other sites More sharing options...
matsfgxr6turbo Member 388 Member For: 15y 6d Posted 24/02/14 12:15 PM Share Posted 24/02/14 12:15 PM These engines have a wastegate problem mainly wastegate is too small and once the cat and exaust is derestricted they generate too much exaust flow for the stock wastegate to handle which then causes a run away boost control issue witrh boost rising with rpm until the engine goes boooooooooooom! Link to comment Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 13y 9m 18d Gender: Male Location: Victoria Posted 24/02/14 12:33 PM Share Posted 24/02/14 12:33 PM Get it tuned and it should be right mate. There's some good tuners in NSW. Money well spent and will be the icing on your turbo Barra cake. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 19d Gender: Male Location: Probably above atmospheric pressure Posted 24/02/14 12:35 PM Share Posted 24/02/14 12:35 PM The ECUs aren't like the jap ones that can tolerate wild boost changes for some reason. Limp mode or boom without a good tune in them.There are stock bottom end BAs getting around these forums tuned by a couple of people that run big numbers, far more power than I am getting from my BFII...but they obviously know what they are doing and keep a close eye on things. Usually because they are smart and also tuning their own personal car. Link to comment Share on other sites More sharing options...
Boganspeed Will do skids for food Silver Donating Members 1,177 Member For: 13y 3m 8d Gender: Male Location: Perth SOR Posted 24/02/14 12:46 PM Share Posted 24/02/14 12:46 PM Aren't the early conrods made of cheese ?I guess it's not a problem if you don't push it. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 19d Gender: Male Location: Probably above atmospheric pressure Posted 24/02/14 12:47 PM Share Posted 24/02/14 12:47 PM That's what makes them so impressive! Link to comment Share on other sites More sharing options...
Boganspeed Will do skids for food Silver Donating Members 1,177 Member For: 13y 3m 8d Gender: Male Location: Perth SOR Posted 24/02/14 12:48 PM Share Posted 24/02/14 12:48 PM And tasty Link to comment Share on other sites More sharing options...
