How Hard Is 298 Rwkw To Handle
Justredd
  • Member For: 10y 11m 18d
the alloy tray is a lot lighter than the heavy steel tub .alloy v steel tub about half the weight .needed 4 people to lift the steel tub ,2 people for the alloy tray .have done it before to my au xr6
  • Member For: 10y 11m 3d
That may be the case with earlier models. FG's have no actual tub to speak of, if you took the plastic lining out you would be looking at the diff and fuel tank through a few rails.
When I first got the ute I wanted to fit some floor-mounted tie down points but there was no tub to weld/bolt to; had to drill through a couple of the (puny) members and use a backing plate to bolt on the stainless lugs I welded up. Carrying around say a gas bottle or heavy bit of round bar the side fitted lugs are good as useless. Handy they are adjustable though.
  • Member For: 17y 1m 22d
I have a 98rwkw tune automatically when it rains. At least forward momentum would indicate as much.
  • To Loud
  • Member For: 13y 1m 16d
^^ +1 I onow how you feel. Same thing happened to me last week. Just kept skating in 1st all the way to 5th. Then when I put it into 6th and over took, well you know the rest. Very nerving situation at that speed.
Mine seems to do it in the same spot up in the hills on the way home every evening if it's been raining. Just after I turn off of the highway. It's uncanny! I blame the cheap tyres.
