  • Member For: 13y 5m 17d
G'day lads. Time has come to dump the factory fill from my 11 XR6T as it's just clicked over 2 years old and done 30K.
What's the best method with the FGs? Previous cars I've just dumped from the bung, flush with hose, fill with demin, run with heater on, dump and repeat (until clear).
Also, what brand / type are you good folk running?
Cheers in advance
Rossco
https://www.fordxr6turbo.com/forum/topic/87626-fg-coolant-replacement/
  • 2 weeks later...
  • Member For: 12y 9m 5d
  On 23/02/2014 at 1:43 AM, CDR_078 said:
Also, what's the best way to get as much coolant out of the block as possibly?
Bottom of radiator on passenger side, undo the bung.
Then locate the heater hoses up near the brake booster, take one of the clamps off and flush water back through the heater core with a hose for a while, do not use big pressure or you may blow the heater core out then your in big trouble! Ha.
