  • Member For: 16y 3m 16d
Has anyone actually fitted 3.25 diff gears to a fg turbo ute, mine has a tray back and its normal drive around weight is 2300 kgs , its recently started to give trouble in the zf gearbox and im told its the clutches in the auto not liking the weight
So I thought shorter diff might help
Thoughts
https://www.fordxr6turbo.com/forum/topic/87625-ute-ratio-change/
  • Member For: 14y 4m 19d
Not using the factory ZF oil could be why you have this long term damage. These boxes are sensitive to oil changes due to differences in temps and pressures. Even more so when using aftermarket trans coolers. Factory oil is by far the best and any external trans cooler needs to be run in series with the factory style heat exchanger (however upgrade the heat exchanger to a stronger unit) and fittings and lines need to be the same diameter as factory.
To answer your question, the shorter gears may help the box a little. But if the damage is done, death is still enevitable.
