PULNGZ Member 25 Member For: 13y 2m 17d Posted 20/02/14 12:39 PM Share Posted 20/02/14 12:39 PM my cars a FG F6 and from when I got it its been making noise from silver pulley on the front of the motor.... normal??? ford man says it is... Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/ Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 16d Gender: Male Location: Probably above atmospheric pressure Posted 20/02/14 01:20 PM Share Posted 20/02/14 01:20 PM Injectors? Are you listening via a screwdriver? Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/#findComment-1456842 Share on other sites More sharing options...
Cheyne_351 Member 20 Member For: 11y 9m 10d Gender: Male Location: Goonellabah Posted 21/02/14 04:01 AM Share Posted 21/02/14 04:01 AM Are you talking about the tensioner? Mine has been making a bit of a tick/rattle noise. Put a screwdriver on the tensioner arm while the car is running and you should be able to feel it if that is it Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/#findComment-1456989 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 16d Gender: Male Location: Probably above atmospheric pressure Posted 21/02/14 05:09 AM Share Posted 21/02/14 05:09 AM Whatever you're hearing, go to the Ford guy and see if you can have a listen to two other brand new cars maybe?That tensioner that Cheyne_351 mentioned is common to need replacing though. Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/#findComment-1457003 Share on other sites More sharing options...
PULNGZ Member 25 Member For: 13y 2m 17d Posted 21/02/14 02:11 PM Author Share Posted 21/02/14 02:11 PM Yeh I think it's the tensioner and it goes and comes. .. The nose that is. . Thought it was normal as its not affecting anything. . Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/#findComment-1457112 Share on other sites More sharing options...
aiboart Member 665 Member For: 20y 3m 26d Posted 21/02/14 11:14 PM Share Posted 21/02/14 11:14 PM The noises make the engine sound crap.In general the noises will not always be present, but, they will likely manifest after a hot run when the engine is at idle.The fix is simple, easy, fast and cheap.1 Get genuine parts from a Ford dealer:Pulley circa $25Tensioner circa $90 (this includes the whole assembly with the metal body, internal tension mechanism and both pulleys)Don't mess with non-genuine parts. It is a waste of time.2 Total changeover time for the pulley and the tensioner for a first timer ---> 20-30 minutesjust remember to remove the thermo fan plate before you try to do anythingthermo fan plate removal --> unclip electrics, undo two bolts visible on the side of the plate and then carefully slide the plate vertically up through its track)the tensioner comes off as a whole assembly, just remove the center bolt. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/#findComment-1457139 Share on other sites More sharing options...
PULNGZ Member 25 Member For: 13y 2m 17d Posted 21/02/14 11:58 PM Author Share Posted 21/02/14 11:58 PM Thanks mate I'll get onto Ford man on Monday. . Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/#findComment-1457144 Share on other sites More sharing options...
PULNGZ Member 25 Member For: 13y 2m 17d Posted 22/02/14 12:54 AM Author Share Posted 22/02/14 12:54 AM Here's the pic anyway.. Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/#findComment-1457148 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 16d Gender: Male Location: Probably above atmospheric pressure Posted 22/02/14 01:29 AM Share Posted 22/02/14 01:29 AM Yeah that's the one. Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/#findComment-1457152 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 5m 27d Gender: Male Location: Dé·jà vu Posted 22/02/14 01:40 AM Share Posted 22/02/14 01:40 AM Serpentine.for future searchs... Link to comment https://www.fordxr6turbo.com/forum/topic/87605-front-of-motor-making-tik-tik-noise/#findComment-1457156 Share on other sites More sharing options...
