Aftermarket Ecu
xrt
  • Member For: 16y 8m 12d
Has anyone gone down the path of an aftermarket ecu for vct control on the coyote yet?
550hp with no aggressive idle just doesnt do it for me anymore.
Is there any options out there ECU wise that will be able to control cams or even just do a 'ghost cam tune' like the mustang guys are getting.
As far as I've heard they cant adjust the exhaust timing, making aftermarket cams pretty much un tuneable and ghost cam tunes arent possible.
Correct me if im wrong but I though that's why tuners such as herrod have failed in their efforts in cam development?
  • Member For: 18y 9m 6d
have not had the rocker covers off one to see what phasers are used, but the ecu has tables to adjust both cams (on each bank) and then adjust separately, same as the turbo does, if the phasers are on inlet and exhaust cams then they should be adjustable with the factory tune, if the phasers are only on one set of cams then no aftermarket ecu is going to adjust them either
  • Member For: 21y 7m
There is no wiring loom to the exhaust cam solenoid. You'll notice there is a little cap over the plug on your cam covers. The Oz ECU doesn't haven't enough outputs to drive the exhaust solenoid I believe.
Benny.
