raiserbackxr6t Member 10 Member For: 10y 11m 18d Posted 18/02/14 09:57 AM Share Posted 18/02/14 09:57 AM Hi all still sorting this problem out. My 02 xr6t running 2008 engine is misfiring but sounds like In one just one cylinder now. I dropped the exhuast at the cat and the load backfiring has stoped. So I'm guessing it's electrical fault. Now the hard part I've change 2 sets of plugs gapped to 0.9mm. Coil plugs have been replaced done cam sensors and tested cam adjusters which tested fine. Fault code comes up bank 2 over retarded. Please help I'm out of ideas. Should I replace the ecu Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 14d Posted 18/02/14 12:00 PM Share Posted 18/02/14 12:00 PM Might be worth pulling off the rocker cover and checking your timing chain hasn't jumped. 1 Link to comment Share on other sites More sharing options...
