blacktur8oute Member 139 Member For: 11y 6m 6d Gender: Male Posted 17/02/14 08:32 AM Author Share Posted 17/02/14 08:32 AM Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1455980 Share on other sites More sharing options...
blacktur8oute Member 139 Member For: 11y 6m 6d Gender: Male Posted 17/02/14 08:39 AM Author Share Posted 17/02/14 08:39 AM yeah its auto and either way with manual shift or auto no real difference up high graph is up thoughts Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1455983 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 1d Gender: Male Location: Adelaide Posted 17/02/14 08:53 AM Share Posted 17/02/14 08:53 AM (edited) looks good. Did you see how the torque curve was after it was tuned. little turbo not much up top 5000- 5250rpm max and grab next gear when WOT Edited 17/02/14 08:57 AM by BiZkets Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1455988 Share on other sites More sharing options...
blacktur8oute Member 139 Member For: 11y 6m 6d Gender: Male Posted 17/02/14 09:14 AM Author Share Posted 17/02/14 09:14 AM no didn't see torque curve bizkets might be just me but was expecting bit more punch don't get me wrong can feel difference in pulling power but dosnt have the wow factor there Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1455994 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 1d Gender: Male Location: Adelaide Posted 17/02/14 10:20 AM Share Posted 17/02/14 10:20 AM (edited) if you get a chance take I down the strip. stock ones are between 13.2 to 13.6 depending on the driver. see what time you can get down the strip. GTX 3582 will make it feel a lot faster;) Edited 17/02/14 10:21 AM by BiZkets 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1456007 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 11m 6d Gender: Male Posted 17/02/14 10:24 AM Share Posted 17/02/14 10:24 AM I wouldn't push much passed 300 on a stock turbo if it where me. The ceramic wheels aren't really cut out for it & the snail's are a lot smaller on the F series to the B series. I'd be happy with 300 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1456009 Share on other sites More sharing options...
Z2TT Member 714 Member For: 13y 12d Posted 24/02/14 12:42 AM Share Posted 24/02/14 12:42 AM Perhaps it may be the factory turbo cannot flow enough air required to keep the pressure at 15 PSI at higher RPM as the engine is running at a faster speed. Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1457464 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 6m 8d Gender: Male Location: WA, Perth Posted 24/02/14 12:57 AM Share Posted 24/02/14 12:57 AM On 17/02/2014 at 7:13 AM, blacktur8oute said: I realise that but is it normal to drop 5 pound a few pound I can understand but 5 major loos of power im thinking of doing the flapper mod with accuator and taking to another tuner as wasn't really happy with overall service also is it normal for the car to idle rough on cold start for the first 30seconds or soBlacktur8oute, I had the same issue. when starting the car in the mornings, I had to wait at least 10 seconds before I could do anything.The car was idling rough. even if I put the foot on the accelerator and tried to give it a bit more RPM to about 1000, it would sputter and almost die out.I spoke to the tuner and they wanted to take the car back in for an overnighter.Then Rob said he changed the scaling for the car and uploaded a new tune file onto the Xcal3.We uploaded the tune and the car has been awesome since.Some FG's react differently to scaling and some are happy as. Who tuned the car out of curiosity? Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1457466 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 4m 20d Gender: Male Location: Christchurch, New Zealand Posted 24/02/14 02:22 AM Share Posted 24/02/14 02:22 AM Id do the actuator if you don't want to change the turbo. My BF use to drop 5psi in the top end with the standard turbo. Did flapper and actuator and it holds perfectly now. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1457478 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 10m 1d Gender: Male Location: Newcastle Posted 24/02/14 04:07 AM Share Posted 24/02/14 04:07 AM Blacktur8ute what power did your car make stock on that dyno? The little turbo will struggle up top which will result in less boost higher in the rev range. Certainly an actuator will help. If the car isn't idling properly with ID1000's then the tune needs adjusting. It should idle perfectly cold or hot. What city are you located in? A bigger turbo would be nice. Certainly fill that drop off in the later part of your graph.Benny. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87564-fg-300kw-but-not-happy/page/2/#findComment-1457495 Share on other sites More sharing options...
