Roley94 Member 114 Member For: 12y 1m 21d Gender: Male Location: Perth Posted 17/02/14 06:08 AM Share Posted 17/02/14 06:08 AM I've heard a bit about but can't find much on it, has anyone done this with 3.23 or 3.45 gears. I know it would make first even shorter and cruising rpm would rise a few hundred rpm. Is there any benifeit especially with 1/4 mile times. Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/ Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 30d Gender: Male Posted 17/02/14 12:25 PM Share Posted 17/02/14 12:25 PM I am thinking of putting 3.23 gears in. Primarily to take the load off the box, no other reason. Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/#findComment-1456025 Share on other sites More sharing options...
Roley94 Member 114 Member For: 12y 1m 21d Gender: Male Location: Perth Posted 17/02/14 12:35 PM Author Share Posted 17/02/14 12:35 PM Would you have to get the zf tuned so it doesn't go into limp mode? Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/#findComment-1456026 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 30d Gender: Male Posted 17/02/14 02:17 PM Share Posted 17/02/14 02:17 PM In Hp tuners and SCT you have to change the gearing ratio. A two second job and 30 sec to download. Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/#findComment-1456033 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 23d Gender: Male Location: SW Sydney Posted 17/02/14 10:29 PM Share Posted 17/02/14 10:29 PM I think a couple of guys tried it not long after the ZF cars came out to try and improve drag times but 1st gear is so short it was not very successful on the strip. They kept banging the limiter almost immediately after getting started. Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/#findComment-1456058 Share on other sites More sharing options...
Roley94 Member 114 Member For: 12y 1m 21d Gender: Male Location: Perth Posted 18/02/14 12:38 AM Author Share Posted 18/02/14 12:38 AM I found some good info on it on the net. People say after some practice with 1st in manual mode its defiantly worth it and fuel economy and cruising doesn't suffer. I may as well give it a go, if I don't like it I can always change back. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/#findComment-1456077 Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 5m 20d Gender: Male Location: Gold Coast Posted 05/08/14 11:55 AM Share Posted 05/08/14 11:55 AM Been informed from Dave Blueboost that the 3.23 is a great mod to do if installing a different LSD TruTrac etc to lower 60s..His tune deletes first gear from auto/performance mode all together and is only available when manually selecting in manual mode..would probably do it myself but the ratio package is very overpriced for what it is essentially :/the commy TruTracs come with the ratios for pretty much the same price as what we pay for the TruTrac alone :( Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/#findComment-1490455 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 10d Gender: Male Location: Brisbane Posted 05/08/14 10:45 PM Share Posted 05/08/14 10:45 PM (edited) I belive qik1 had 3.7's in his for a bit and said it was pretty hopeless....he is running 1000hp mind you....Also gun I think Vt-vz ran an m86 centre so wouldnt the gears be the same? Edited 05/08/14 10:47 PM by barnz Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/#findComment-1490525 Share on other sites More sharing options...
GUN-808 Member 251 Member For: 11y 5m 20d Gender: Male Location: Gold Coast Posted 06/08/14 12:05 PM Share Posted 06/08/14 12:05 PM They may have mate im not sure..going off the site I have here with TruTracs the VL-VT1 used a 28pline job so maybe the VT forward is different and they dont list a model for them..Its more the newer Commies that have the stuff that is half the price as Ford bits..the VE its says has 32 spines.. Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/#findComment-1490733 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 10d Gender: Male Location: Brisbane Posted 07/08/14 03:09 AM Share Posted 07/08/14 03:09 AM Hmm may be worth investigating further but if we could use the same centre and gears and its just a pricing stitch up surely somebody would be onto that by now so their may he a minor difference. I havent double checked but I think our cars are 30 splines 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87563-anyone-changed-the-diff-ratio-with-a-zf-auto/#findComment-1490862 Share on other sites More sharing options...
