  • Member For: 14y 5m 19d
Not sure where this one should go, it doesn't really fit anywhere.
So nothing is coming out of my windscreen washer nozzles (FG MkII). There's definitely fluid in the container, it was low so I filled it up but it definitely wasn't empty. I can hear the pump working, at least it sounds like its working but nothing comes out of the nozzles. I didn't like to keep pulling the lever for too long, I was afraid it might burn out the motor.
I do remember reading something similar and it was a common fault but I can't find the thread. I seem to remember it being a pain in the arse to get to whatever needed fixing but it wasn't actually hard to fix...just wondering if its easy enough to fix before I take it to Ford instead (still under warranty).
  • I <3 Floods
  • Member For: 13y 10m 7d
Never played on a MKII..
Check there is water in the line that runs to the nozzle.. If there is stick a pin down the squirter I have seen gunk in them a few times..
But I've also had luck running water water through it to clear it out.. Mixed with a bit of decent cleaner (like exit mould or something) just incase there was some mould or something funky blocking the line..
Edit: jut read warranty..
Try the pin.. If that doesn't work let ford fix it..
Edited by Slightly Depressed Panda
  • Member For: 11y 6m 18d
Mine have done it twice and its not the nozzles which I have cleaned, ford "fixed" it.. was okay for about a week then the drivers one stops again, hose was full of crap, like little sticks and stuff. Apparently ford just use a bucket of water from the local creek/dam to fill your washer bottle.<br /><br />Sent from my Nexus 7 using Tapatalk<br /><br />
  • Like 2
Thanks guys, I shall try the tips when I get home from work.
As for the algae build up, is there any way to stop it? Any sort of chemical we can add to stop it growing that isn't going to also ruin the pump or washer blades?
  • Moar Powar Babeh
  • Member For: 19y 8m 15d
Clean it out and add a small amount of bleach (like 1/3 a capful) and run either distilled water or tap water and washer fluid.
  • Member For: 18y 8m 10d
I just normally pull the hose off the back of the squirter and press the trigger to see if that's ok
  • 7 years later...
  • New Member
  • Member For: 11y 3m 4d
Any ideas how to remove/replace the nozzles without removing the complete full length panel that they plug into , 2012 XR6T
 FG model
One of mine broke off during attempted removal/cleaning
Cheers
