  • 1 month later...
  • Bronze Donating Members
  • Member For: 11y 5m 18d
Hey guys sorry to be a pain in the arse but does anyone no if these will fit my ba f6 ute?
19 x 9.5 +15
19 x 10.5 +15
I think the fronts should fit with a bit of poke not sure about rears though
  • Member For: 11y 4m 19d
I just did a bunch of test fits with rims I had laying around,
First of was a set of rezax off my s14
Rear a 18x10+0 had a good inch poke. My ute is stock height, this would normally camber in a touch when lowering, but due to solid rear im guessing it will just look mexican and more than likly munch the gaurds on compression once lowered, Similar case with the matching front being a 18x9-4 it too poked a good inch, though at least this would come in a bit with natural camber after lowinging it
The main issue seems to be that the tub actually recceses back in, so from the top doesnt look like a lot of poke but actually is, like the opposite of a pumped gaurd
Shame as I think they would actually suit it once lowered with appropriate tyre size and would save me buying another set of rims
cb5e3525-1d75-4588-b66e-7649b7ac1f76_zps
I then tried some 17x9+20 BBS RS, looked good. Th issue was they required too much spacing as center bore was too small to actually drive on them. By the time they were spaced out they were at a 9+12 and just inside the gaurds.
There was no use to try much else I had as they are all 17x10 in neg offsets and would have no chance
Unfortuantly the rain started to get heavier so I forgot to take pics.
But im going to aiming for a pretty boring 18 or19 9.5+15ish rear and 9+12ish fronts as want to minimise chance of scrubing while towing. At least this is a fairly common size and easy to find something non china
Edited by (Locky)
  • Member For: 11y 6m 22d
After alot of maths and searching I'm pretty certain a 9.5 will fit under the front guard, 9.5 +23 should fit just right by my calculations, test fitting a 9.5 +12 this weekend but I know it will be too far out
Yeah will take a photo or or two mate, I'm getting new wheels and my only options are 8.5+35 and 9.5+35, the 8.5's will be fine but I know the 9.5's will need a spacer, just how big lol
