genx2g Member 95 Member For: 11y 3m 30d Posted 06/02/14 05:13 AM Author Share Posted 06/02/14 05:13 AM this is what its doing Link to comment Share on other sites More sharing options...
genx2g Member 95 Member For: 11y 3m 30d Posted 06/02/14 05:28 AM Author Share Posted 06/02/14 05:28 AM sounds like the door motors are locking up Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 28d Gender: Male Location: Perth Posted 06/02/14 05:31 AM Share Posted 06/02/14 05:31 AM It's hammertime 1 Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 9m 26d Gender: Male Location: ACT Posted 06/02/14 06:13 AM Share Posted 06/02/14 06:13 AM I get that 'sound' when a door is still open... ! Link to comment Share on other sites More sharing options...
genx2g Member 95 Member For: 11y 3m 30d Posted 06/02/14 06:45 AM Author Share Posted 06/02/14 06:45 AM yea, I know what you mean fwolf, I opened all doors and boot, closed them all properly and still does the same thing. and the light showing a door is open on the dash isnt coming up Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 9m 26d Gender: Male Location: ACT Posted 06/02/14 06:54 AM Share Posted 06/02/14 06:54 AM (edited) Also found this... The most likely cause of this is a sticking door ajar switch...the door ajar switches are located within the door latch...if you have a can of spray brake cleaner or carb cleaner, go to the drivers door, open the door, now spray for 5 seconds into the door latch..then open and close the door 10 times...repeat this with the other doors and then check to see if the warning light goes out and locking returns to normal. justanswer.com/ford/5xm7w-ford-falcon-doors-closed-02-ba-falcon-says-door-ajar.html I think we are getting somewhere... Just went under the house / garage... This is what I did. Opened driver door... window down so I can open door via the inside handle. Pressed lock button on remote... Horn sounds. Next I used a philips screw diver to look the door lock while door is still open... Pressed lock button on remote... Horn will not sound but all doors will be locked. So... I think you may have a stuck door switch. Edited 06/02/14 07:00 AM by f-wolf 2 Link to comment Share on other sites More sharing options...
genx2g Member 95 Member For: 11y 3m 30d Posted 06/02/14 10:32 AM Author Share Posted 06/02/14 10:32 AM f-wolf you're a champion. thanks soooo much for your help, much appreciated.I'll be sure to give that a try 1 Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 11m 26d Gender: Male Location: Frankston, 3199 Posted 06/02/14 10:52 AM Share Posted 06/02/14 10:52 AM Bloody hell f-wolf - you seem to have the right leads on everything (looked up some of your other posts)You either know your sh*t, have had a car that has had a heap of problems or have crazy google skills.Am tipping it's a bit between number 1 and number 2 2 Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 9m 26d Gender: Male Location: ACT Posted 06/02/14 11:09 AM Share Posted 06/02/14 11:09 AM Thank you raband... I spend nearly 40 years working on small and big wheels. Also worked on large computer controlled Automatic Transmissions made by ZF, Renk, and Voith for many yearsAnd I never give up... LOLJust need the right tools... anything can be fixed. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 11m 26d Gender: Male Location: Frankston, 3199 Posted 06/02/14 11:17 AM Share Posted 06/02/14 11:17 AM So....., You know your sh*t and have had your share of vehicles with problems Link to comment Share on other sites More sharing options...
