D DUB Member 56 Member For: 11y 11m 19d Gender: Male Location: central coast NSW Posted 05/02/14 07:25 AM Share Posted 05/02/14 07:25 AM This morning driving to work I turned a corner and my lights cut for a second or two. It happened again and then I realised that every time I indicated my lights would cut in and out. A couple of times I had to turn them on and off to get them to kick back in again. If I pulled the indicator stalk even a mm back towards me, they'd flicker. I'm assuming its a loose connection or something in the stalk?? Any other ideas? Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 8m 11d Gender: Male Location: ACT Posted 05/02/14 11:20 AM Share Posted 05/02/14 11:20 AM It is a common fault, the combination switch wiring fails. You can fix this yourself. On the indicator stalk if you remove the small plastic cover that pops out behind the stalk you will see the wires have broken, just solder them back together and your done. From: www.justanswer.com/australia-car/36fzx-ba-2006-xr6-sedan-headlights-gone-ford.html Link to comment Share on other sites More sharing options...
D DUB Member 56 Member For: 11y 11m 19d Gender: Male Location: central coast NSW Posted 05/02/14 07:51 PM Author Share Posted 05/02/14 07:51 PM Good stuff. Thanks for the tip mate. I'll get onto it this weekend. Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 19d Gender: Male Posted 06/02/14 08:57 AM Share Posted 06/02/14 08:57 AM I fixed mine, and wished I had just replaced the ASSY when someone told me how cheap they were, I forget how much though but its a slightly awkward job. Link to comment Share on other sites More sharing options...
