genx2g Member 95 Member For: 11y 3m 11d Posted 04/02/14 10:07 AM Share Posted 04/02/14 10:07 AM Hey guys I have a 2005 ba xr6t and recently ive been noticing a problem with the revs and it is getting worse.when almost coming to a stop or reversing my revs drop a fair bit and almost stall (this car is auto) and get some engine noise.Anyone have an idea of what it could be? it has got me scared. Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 9m 7d Gender: Male Location: ACT Posted 04/02/14 11:27 AM Share Posted 04/02/14 11:27 AM Your Car still could have the old Throttle Position Sensor Unit.If it looks like this... its the new type. But if its got a depression on the flat surface you still got the old one... Link to comment Share on other sites More sharing options...
genx2g Member 95 Member For: 11y 3m 11d Posted 04/02/14 07:14 PM Author Share Posted 04/02/14 07:14 PM so replace it with the new one if I still have the old one? and that should fix my problem? Link to comment Share on other sites More sharing options...
silverjet New Member 14 Member For: 14y 1m 28d Gender: Male Posted 04/02/14 07:57 PM Share Posted 04/02/14 07:57 PM It might fix your problem. Do the TPS first as it will improve the overall situation then check your intake manifold gasket isnt leaking my BA t ran like a sack until I sorted the intake gasket and tps Sent from my anus using Tapatalk 2 Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 9m 7d Gender: Male Location: ACT Posted 04/02/14 09:17 PM Share Posted 04/02/14 09:17 PM (edited) My Car... 2005 BA MK2 Turbo 6 speed Manual.When cold would idle at 1200 rpm...When hot it should have been doing 750 rpm...But it used to dip below 750 rpm when pulled up at traffic lights...It used to go so low at times that it would stall...Sometimes it would go so low the Engine would make some " strange " noises but recover back to 750 rpm.I then replaced the TPS with the new Type and all was well after that.1200 rpm when cold... 750 rpm when hot. Edited 04/02/14 09:19 PM by f-wolf 1 Link to comment Share on other sites More sharing options...
genx2g Member 95 Member For: 11y 3m 11d Posted 05/02/14 04:11 AM Author Share Posted 05/02/14 04:11 AM that's my problem exactly f-wolf. where am I able to purchase the tps? Link to comment Share on other sites More sharing options...
genx2g Member 95 Member For: 11y 3m 11d Posted 05/02/14 05:49 AM Author Share Posted 05/02/14 05:49 AM I was told that it could also be my battery, had someone test it and it was @ 144 cc which is low apparently and that could be the problem. Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 9m 7d Gender: Male Location: ACT Posted 05/02/14 07:13 AM Share Posted 05/02/14 07:13 AM (edited) Re, ...where am I able to purchase the tpsTry Ebay.You must be very careful when you undo the 2 screws holding the unit in place !!And also when you put the screws back in.They are very easy to break off.Try to get some heat in to the area around the bolts before you try to get them out !!! Edited 05/02/14 07:19 AM by f-wolf Link to comment Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 5m 11d Gender: Male Location: Melbourne, VIC Posted 11/02/14 04:53 AM Share Posted 11/02/14 04:53 AM I had the same problem ages ago. When coming to a red light it would drop revs and stall, it became fairly frequent that I ended up putting it into neutral when coming to a stop, so then I could switch it back on quickly, was a pain in the ass..Dunno exactly what fixed the issue, I got a retune for some mods and the problem never came back, I always thought it was the tune that was the cause. Everywhere I asked said it was this or that but with no definite answer. Have you had your car tuned recently? Link to comment Share on other sites More sharing options...
matsfgxr6turbo Member 388 Member For: 14y 11m 26d Posted 11/02/14 08:42 AM Share Posted 11/02/14 08:42 AM The problem is tony abbot I'm pretty sure he is responsible for everything at the moment because bill shorten says he is so it must be true. 2 Link to comment Share on other sites More sharing options...
